lexus ls430, amp with mark levinson system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109518
Printed Date: April 23, 2026 at 7:47 AM
Topic: lexus ls430, amp with mark levinson system
Posted By: mrmopar
Subject: lexus ls430, amp with mark levinson system
Date Posted: December 05, 2008 at 11:20 PM
has anyone installed an aftermarket amp into the factory system with the mark levinson audio/gps system?Tryung to do this on a lexus ls430.
cbsalley
Posted By: cartronicshn
Date Posted: December 19, 2008 at 7:05 AM
I would go with RF 3sixty-1 or 3 sixty.2 systems., that will give you 3 stereo channels of clean preamp outputs.
Posted By: mrmopar
Date Posted: December 19, 2008 at 4:06 PM
I am nit familiar with the rf361 or rf362,my problem so far is the connections i have tried using R+ R- L+ L- from component tuner to amp is i have no volume control just steady sound.Any help would be greatly appreciated thanks Chris.
cbsalley
Date Posted: December 21, 2008 at 6:23 PM
Link to the processor form Rockford
https://www.rockfordfosgate.com/products/product_categories.asp?cat_id=1
This should give you all the tunabiltiy on that lexus, at least that's waht i am hoping for, i am doing that same deal tomorrow, i will keep you posted of my findings.
Posted By: i am an idiot
Date Posted: December 21, 2008 at 6:36 PM
You need to connect the line out converter to the output side of the amplifier.  You probably need to use a Pac-audio.com  sni-35
Date Posted: December 22, 2008 at 11:53 AM
The reason why you probably can't control the volume, is because they are controlled internally by the levinson amp, i am having the same problem, but i will try to bypass the stock volume knob, i'll keep posting  'till i solve this.
Date Posted: December 22, 2008 at 2:08 PM
Well, we finally have volume control from the head unit, we hardwired the 3sixty processor's volume control, and left the RF software control at main, no subwoofer control though, but i have 6 channels of clear sound, now on to speaker changing, going with punch components for doors, and trying to fit an elemnetal design eu 700 6.5 woofer
