sound cutting out
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110255
Printed Date: April 03, 2026 at 11:10 PM
Topic: sound cutting out
Posted By: sbhop36
Subject: sound cutting out
Date Posted: January 02, 2009 at 10:15 AM
whenever i press my brakes my highs cut out kenwood amp
sbhop boomin' @36
Posted By: DYohn
Date Posted: January 02, 2009 at 10:31 AM
Then don't press your brakes.
posted_image
Seriously, how did you wire it?  Where is it getting power?  How is it grounded?  What vehicle?  What other gear is in the system? And what do you mean by your "highs cut out" the Kenwood amp?  Is it the main amplifier or the subwoofer amplifier giving you trouble?
Posted By: i am an idiot
Date Posted: January 02, 2009 at 5:40 PM
Is that the only amp you have on the system?   Have you looked behind the brake pedal to see if there is a wire that is being put into a bind when the brake pedal is pressed?   Does this happen only when the car is in motion and you hit the brakes?
