radio diagram ford e150 2006
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110637
Printed Date: April 18, 2026 at 8:19 AM
Topic: radio diagram ford e150 2006
Posted By: hewano
Subject: radio diagram ford e150 2006
Date Posted: January 14, 2009 at 8:27 AM
Does anyone have the radio diagram for the Ford E 150 2006
Thank you
Posted By: donvito08
Date Posted: January 17, 2009 at 12:13 AM
Assuming you ment F-150 here it is
Battery WHITE/ YELLOW (+) RADIO HARNESS
Accesory WHITE/ RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED / BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
RR Speaker (-) BLACK
Amp Location MOUNTED TO BRACKET IN RIGHT SIDE OF TRUNK
Steering Cntrls YES
Speed Cntrl NO
Radio Security YES
MOBILE SECURITY SPECIALIST
MECP CERTIFIED INSTALLER
SELF CERTIFIED SMARTASS
Date Posted: January 17, 2009 at 12:43 AM
sorry posted wrong diagram
Battery LIGHT GREEN/ VIOLET (+) RADIO HARNESS
Accesory LIGHT GREEN/ YELLOW (+) RADIO HARNESS
Illumination LIGHT BLUE/RED (+) RADIO HARNESS
LF Speaker (+) ORANGE / LIGHT GREEN
LF Speaker (-) LIGHT BLUE/WHITE
RF Speaker (+) WHITE/ LIGHT GREEN
RF Speaker (-) DARK GREEN/ ORANGE
LR Speaker (+) GRAY/LIGHT BLUE
LR Speaker (-) TAN / YELLOW
RR Speaker (+) ORANGE / RED
RR Speaker (-) BROWN / PINK
Steering Cntrls OPTIONAL
Speed Cntrl YES
Radio Security YES
Posted By: i am an idiot
Date Posted: January 17, 2009 at 2:54 AM
There is no radio wiring info on this site nor Audiovox's website for your Econoline. There is a good chance that it shares the same wiring as it's pickup counterpart. If it does not share the same wire colors as above, you could always purchase the 15 dollar harness, then the wires from your new radio will match the harness wires color for color.
Posted By: hewano
Date Posted: January 17, 2009 at 10:37 AM
Thank you. Funnily enough it had a bit of everything and two black / green ground wires but I have sorted it out now
