how to run subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110669
Printed Date: April 18, 2026 at 1:44 PM
Topic: how to run subs
Posted By: mototolashane
Subject: how to run subs
Date Posted: January 14, 2009 at 8:58 PM
I have 2 MA Audio MA151XQ 4ohm DVC subs and Sony XM2002GTR amp. The vehicle is a 87 Ford Econoline 150 and i dont know if i should run the subs at 2 or 4 ohms.
Posted By: ccityroadshop
Date Posted: January 14, 2009 at 9:37 PM
well whats the power rating on the subs?  that amp is a two channel amp 400 rms so 200 to each sub im sure that would be at a 2 ohm load for that amp, what kinda box you got?
mustang GT convertible with lots of performance mods... Alpine M500 amp with sealed enclosure, 10 inch kappa perfect, clarion cz500 head unit, kicker ks speakers all around
Posted By: i am an idiot
Date Posted: January 14, 2009 at 10:06 PM
With DVC 4 ohm drivers, your choice is 1 ohm or 4 ohm.  You need to run that amp at a 4 ohm load.
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
posted_image
Date Posted: January 14, 2009 at 10:57 PM
ah yea that is right forgot bout it being two dual 4's, yep run it at 4
Date Posted: January 14, 2009 at 11:02 PM
haha hold up now i remember why i was saying 2 ohm load, its because its a 2 channel amp, so you would wire each channel seperately to each sub going parallel to each sub
Date Posted: January 15, 2009 at 7:34 PM
i guess im gonna run them each separate the amp says it can handle 250 watts x 2 at 2 ohms and im probably gonna go with a sealed box but may go all out with a vented box
