parking wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110697
Printed Date: April 18, 2026 at 6:25 PM
Topic: parking wire
Posted By: time2dcaudio
Subject: parking wire
Date Posted: January 15, 2009 at 9:44 PM
Hey does anybody know the color of wire to the emergaency parking break wire? Ineed to hook up a dvd player and b4 i used to get away with using ground but thats not working so now i need to find that wire can n e body help? Its for a 2002 chrysler pt cruiser. Looked up daigram on your site and that also was either wrong or his car is different.
15,0000rms and 12 edx12s
Posted By: j.reed
Date Posted: January 16, 2009 at 12:24 AM
PLZ read the forum rules again. Really carefully posted_image
posted_image
Posted By: i am an idiot
Date Posted: January 16, 2009 at 7:24 AM
He has been doing it  the wrong way for some time.  Now he is asking for help in attempting to follow the rules.
I have no idea on that vehicle, but I can probably help you find it,  at the pivot point of the brake lever or pedal.  There will be a single wire going to that area.  Use a meter to verify that the wire has ground on it when the brake lever/pedal is engaged.
Time2,  there is a problem with your signature line, is the comma in the wrong place, or did you put too many zeros??
Posted By: j.reed
Date Posted: January 16, 2009 at 1:31 PM
Yeah Im sorry. It was late and i was in a bad mood. All i payed attention to was "bypassing in the normal way: he did it.
Yes, i am an idiot is right. Look at the e brake at the base. there will be switch with the wire you need.
posted_image
