alpine tweeters too bright gurus.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111208
Printed Date: April 03, 2026 at 2:39 AM
Topic: alpine tweeters too bright gurus.
Posted By: raverx3m
Subject: alpine tweeters too bright gurus.
Date Posted: February 01, 2009 at 3:32 AM
ok heres my issue.
i have a pair of alpine sps-171a
1"textile dome tweeter
50watt RMS
90DB sensitivity<<<
and bought a pair of alpine sps-600C
1"silk dome tweeter
80watt RMS??doubt it
88DB  sensitivity.
to replace my front woofers thinking they are worn out but to  my surprise they put the new speakers to shame so i left them there and put the new ones in the back(acura integra)
i did put new tweeters in my front doors tho and old ones in the back since they were all scratched up and dented grilles as you notticed the sensitivity on the 600c is less. but the new tweeters sound ridiculously loud compared ot my old ones. even with the -3db setting in the crossover. and i turn my treble all the way down to make them sound lil quieter. i mean physically they are almost identical in cone shape, magnet size and all
what can i do?
Posted By: DYohn
Date Posted: February 01, 2009 at 9:35 AM
You can't just swap tweeters like that and expect good results.  Crossovers are designed for the specific speakers they are designed for, and changing them may or may not work out well.  There is a lot more to it tham simply sensitivity and size.  You need to use the correct crossover that came with the component set.
Posted By: raverx3m
Date Posted: February 01, 2009 at 12:43 PM
how would i find out the specs of that tweeter tho?
the 171a are actual components
and 600c are just separates with capacitor  inline for tweeter.
i couldnt find any replacement tweeters for them so  i went with the closest i could find locally(at the shop i worked) for cheap
Posted By: soundnsecurity
Date Posted: February 02, 2009 at 10:56 AM
you can play around with the direction and angle of the tweeters to maybe take some of the harshness out
Posted By: jmelton86
Date Posted: February 03, 2009 at 9:10 PM
I just looked both of those model #'s up and they are both from component sets.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
