93 honda prelude no sound
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111563
Printed Date: April 01, 2026 at 11:58 AM
Topic: 93 honda prelude no sound
Posted By: nathanh
Subject: 93 honda prelude no sound
Date Posted: February 13, 2009 at 2:04 PM
I have a 93 honda prelude and a few months ago had the stock CD player lock up on me. I couldn't find the security code, so I just replaced it with another unit. Things went fine for a while, but then a month after I installed it- the sound went out. I assumed it was the stereo because it was a piece of crap anyways, but I bought a new CD player yesterday and installed it. Still no sound :( This makes me sad. I triple checked the wiring, all connections were solid, and everything is perfect. But still no sound. Checked fuses, in the off chance a wrong fuse had been used and was causing strange things to happen... Nope. EVERYTHING is perfect... Then something strange happens, I was fiddling around with the wires, and then the sound came on... but when I shut the hood of the car- the sound went back out :( No sound... But I can hear power coming through the speakers. Is this a short in a wire somewhere? Which wire would cause this? Is it not properly grounded or something? What is going on?
------------- "To be a person is to have beliefs. To have beliefs is to feel. To feel is to be human- and to be human is an awkward thing."
Nathan
Posted By: 02-mti-z07
Date Posted: February 14, 2009 at 5:30 AM
sounds like a short but in this situation its hard to tell. Get you a volt meter and some free time and start the long tedious process of checking wires. Most likely the hood being closed jarred something into working. A 12 volt test light might make your life a little easier.
------------- 05 mazda tribute: H/U Alpine IVA W-505/A pillar BA Neo Type M's/Doors 2xBA SL-85's/subs 2xBA G5 10's w/passive radiators/Proc Alpine PXA-701/Amps JL 300/4v2&1000/1v2 Power 4 gauge/200amp alt
Posted By: i am an idiot
Date Posted: February 14, 2009 at 6:37 AM
Is there a Bose emblem on any speaker cover in the car?
Posted By: t&t tech
Date Posted: February 14, 2009 at 6:04 PM
when i encounter problems like that, what i do is, remove the deck from it's mounted position, and place it a little bit away from the dash area ao u can work, turn the unit on andleave it on even though no sound comes out, then wire by wire cut the speaker leads from the deck, when the sound comes on you've found the wire that was grounding, normally a grounded speaker lead causes that. -------------
Posted By: nathanh
Date Posted: February 14, 2009 at 9:58 PM
Ha ha! I feel so dumb.
My first thought was that I had a speaker grounding somewhere, but I was pretty sure that wasn't the case :P
I remembered I heard a little static coming from the rear right, popped the trunk and found that some stuff rolling around in the trunk had pulled the + and - wires loose and they were touching :D
I guess when I shut the hood, it just jarred the wires enough to touch again...
I guess there were very few problems that really could have caused it, and it was only a process of elimination. Good thing it was so simple... But I guess sometimes I forget the simple solution :P
Thanks for the help guys!
Nathan
