no sound, 93 honda prelude si
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111683
Printed Date: April 25, 2026 at 10:47 PM
Topic: no sound, 93 honda prelude si
Posted By: stryker916
Subject: no sound, 93 honda prelude si
Date Posted: February 17, 2009 at 11:08 AM
This maybe a noob problem and I am sure I am overlooking something but i have spent 2 hrs in the Chicago cold and my brain is fried. I have a Alpine CDA-9857. I recently bought a Alpine 12'' Type X SWX-1243D powered by a Hifonics Brutus Bxi2608D Mono Amplifier. The amp has power but i have no sound coming from the sub. This is the first time I have hooked up an amp to this head unit and this also my first time with Hifonics amplifiers. I know the problem must lie in the RCA Cables but I have tried every configuration. Is there somthing I am missing? In the Hifonics manual There is talk of the possibility of needing a RCA Y adaptor. Would that cause no power in the sub? I'm sure this is a easy answer for someone here, and I am sure they are laughing their ass off. Laugh all you want just tell me what I did wrong please. Thank you in advance.
Date Posted: February 17, 2009 at 11:09 AM
It's a 93 Honda prelude Si
First post and I already mess up.
Posted By: soundnsecurity
Date Posted: February 17, 2009 at 12:13 PM
make sure the subwoofer output RCA is turned on in your radio's menu. some have an option to turn it on and off so make sure yours isn't off.
you should only need a Y adapter if your radio's subwoofer output is mono and not stereo.
Date Posted: February 17, 2009 at 1:19 PM
Checked that already. It does have a on/off function for the AUX but it didn't solve my problem.
Date Posted: February 17, 2009 at 2:44 PM
does it have more than one RCA output? like front or rear? have you tried hooking it to another output just to see because that sub output might just be bad.
Date Posted: February 17, 2009 at 2:56 PM
It has front rear and sub I tried them all. I am on my way to go get new RCA cables to see if that fixes it.
Date Posted: February 17, 2009 at 3:09 PM
before you buy new stuff do one last check. make sure the speaker wires from the sub to the amp are wire correctly at the amp. some hifonics amps set up their terminals ++-- not +-+- and if you didn't catch this it can be easy to mess up. just make sure your sub is not wires to both positive terminals
Date Posted: February 17, 2009 at 3:38 PM
FIXED! Bad RCA cables! Thank you for everyones help!
