94 plymouth laser
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11185
Printed Date: April 01, 2026 at 4:52 AM
Topic: 94 plymouth laser
Posted By: juggalette
Subject: 94 plymouth laser
Date Posted: March 20, 2003 at 5:21 PM
sooo I just bought a plymouth laser..94 and it only had a tape deck in it. generally speaking im alright at hooking up stereos...but I seem to be having issues withthis one. If anyone knows the color codes for the stereo diagrams for a 94 plymouth laser and could give me any tips, i would really appriciate it! thanksa ton
Posted By: the12volt
Date Posted: March 20, 2003 at 5:31 PM
Date Posted: March 20, 2003 at 7:03 PM
well umma....so I got the power and what not to work..thanks! now though when i turn the ignition the stereo turns on for maybe a second or two then turns off...the ground and everything is secure. if I pull the key out and turn it again it turns on for a second or two, however if I don't pull the key out and just turn it the stereo does not turn on! if you could help me yet again cause Imma silly head it would be great! thanks again
Posted By: esmith69
Date Posted: March 20, 2003 at 7:07 PM
Does it go out if you turn the vehicle on? Or just when you turn the key to the ACC position? And do you hear any weird noises just before it shuts down?
Posted By: Velocity Motors
Date Posted: March 20, 2003 at 7:14 PM
Where do you have your ground ? I ask because I installed a stereo the other day in a UK spec'd VW Passat and the GROUND wire from the back of the radio wasn't an absolute ground and I had the same problem. I ended up just taking a ground from the lighter and it worked like a charm.
------------- Jeff
Date Posted: March 20, 2003 at 7:18 PM
the stereo turns off no matter what. and i have the ground touching metal on the interior of the stereo, thats what I was told to do. I mean it seems liek it should work, it just doesn't want to stay on longer than a few seconds!
Posted By: dragonrage
Date Posted: March 20, 2003 at 7:35 PM
If you have a voltmeter, measure the voltage from + to ground, both of them should be between 12 and 14 (about 12 if car is off, usually about 13.5 if it is on)
------------- 2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
