i keep blowing my jl amps
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111904
Printed Date: April 05, 2026 at 9:57 AM
Topic: i keep blowing my jl amps
Posted By: joeeeeker
Subject: i keep blowing my jl amps
Date Posted: February 24, 2009 at 4:35 PM
Okay here's the situation: my JL 500/1v2 had a problem that i've posted here a couple months ago. The power light to my amp turns on, but no output. Member "i am an idiot" has informed me that it may be because the power supply has failed. Planning to ship my amp out to him to fix. Meanwhile, i've been running my 1000/1v2. With my horrible luck, the same problem has struck my 1000/1. Now, I'm not sure if this is because i'm not tuning the input sensor incorrectly(which i believe i am), or if JL amps have a tendency to have these problems. Any input appreciated.
Posted By: DYohn
Date Posted: February 24, 2009 at 4:42 PM
What kind of load are you putting on it? ------------- Support the12volt.com
Date Posted: February 24, 2009 at 5:00 PM
running a 4 gauge setup with a circuit breaker to a 5 farad cap
Posted By: ragsports
Date Posted: February 24, 2009 at 6:39 PM
I think Dyohn meant What is the total load placed on the amp by your subwoofers. What kind of subwoofers are you running? How do you have them wired? What are the ohm ratings of the voicecoils?
Posted By: forbidden
Date Posted: February 24, 2009 at 7:30 PM
And have you verified with a meter that you have a proper ground.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: riniflex01
Date Posted: February 24, 2009 at 10:39 PM
I had a similar problem. At times my amp would shut off for no reason. If i turned the volume down it would come back on. My dealer was trying to trouble shoot it, since i couldnt figure it out and was pulling my hair out after weeks. Finally we changed from a 100 amp circuit breaker to the JL audio 100 amp fuse holder. Standard tube fuse. That solved the problem. JL said that there was too much resistance thru the circuit breaker......
Date Posted: February 24, 2009 at 10:40 PM
Oh sorry forgot, I have 2 12" w6 v2's with a 1000/1 amp
Posted By: DYohn
Date Posted: February 25, 2009 at 1:50 PM
And you probably have them wired for 1-ohm, correct? Did you follow JL's procedure for setting the gain to support a that load? ------------- Support the12volt.com
Date Posted: February 26, 2009 at 12:50 PM
My dealer tuned it and retuned it, he said he checked everyting with a volt meter at 4 ohms 3/4 volume ect...... the final impedence of the subwoofer enclosure is four ohms. The box comes pre wired, and i cant find a wiring diagram, but the specs say 4 ohms........unless im missing somthing? I not an expert like most of you guys.
Date Posted: February 26, 2009 at 12:52 PM
Posted By: DYohn
Date Posted: February 26, 2009 at 1:20 PM
That's good. 4-ohms is much easier on the amp than 1-ohm. Well if the dealer set it up for you and it blew then I assume the dealer will honor the warranty. ------------- Support the12volt.com
Date Posted: February 26, 2009 at 1:24 PM
my amp never blew, it was shutting off somtimes. When i would turn the volume down it would come back on. They even sent it back to JL for testing, then changed from a circuit breaker to a JL audio 100 amp fuse
