suggestions for an upgrade
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112060
Printed Date: April 04, 2026 at 8:21 AM
Topic: suggestions for an upgrade
Posted By: vipercrazy
Subject: suggestions for an upgrade
Date Posted: March 02, 2009 at 5:42 PM
im swapping my system into my new car soon and since i went pretty cheap with it(ok dirt cheap) id like to swap some new goodies in. i want this system to be loud but at the same time still be able to adjust my bass enough that i can hear vocals.
i have a 1980 benz 280ce, and what i plan on keeping for the new system is my sony head unit and bazooka 3.5" coax's in the dash(i think 50w rms), the hu looks just like a cdx710 but it has the movie type screen. i can never find the model online.
i would like some suggestions on what wattage i should go with for the amp. i was thinking of getting a single 10" sub for the trunk since my cabin space is pretty small. i dont need really deep bass but i want it to go loud. anything is louder than the HU amp im used to im guessing.
i was suggested to go with any 5.25 comp speakers for the rear deck lid and to power them off the HU. with that i can use my amp for the 3.5"s and sub. are there some brands of comp speakers i should stay away from? im guessing i should go with a 4 channel amp, so would 2 channels into one sub be good, or would two channels into two subs be that much better?
i know thats a ton of questions but if anyone has suggestions for the best possible setup for a budget of about 4-500 for the amp, sub, two comps, and everything to wire it, give me some ideas.
Posted By: j.reed
Date Posted: March 02, 2009 at 5:53 PM
As for wattage of an amp you should get that really is up to the speakers you choose. To power 2 fronts and one sub a 4 channel amp would do well. Most 4 channel amps are only capable of a 4 ohm bridge. So you would want a sub that is dual 2 ohm or single 4 ohm. the remaining 2 channels of the amp could be used on you fronts As for brands there are many. Depending on how loud you want to play a better d class amp and better sub would get you far as bass goes. You can always add a LC-1 which will allow you to have sub volume control. -------------
Date Posted: March 02, 2009 at 6:23 PM
thanks for such a quick reply ill look into class d amps, its a ton easier picking from cause there arent too many of them, i want looking at this one
https://www.online/CarAudio/ProductDetail.aspx?Productid=18485
is it a bad idea to get an amp thats 4x70w rms at 4ohm when my speakers up front are 50w, would i just have to set a volume limit?
Posted By: j.reed
Date Posted: March 03, 2009 at 8:02 PM
you should be fine. The key is in setting the gain right. Follow the sticky post. https://www.the12volt.com/installbay/forum_posts.asp~TID~85479~PN~1-------------
