jl 10w7 vs 2x 12w6v2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112079
Printed Date: April 04, 2026 at 5:51 PM
Topic: jl 10w7 vs 2x 12w6v2
Posted By: joeeeeker
Subject: jl 10w7 vs 2x 12w6v2
Date Posted: March 03, 2009 at 2:00 PM
not sure what i want to run out of my trunk.. would appreciate anyones input
Date Posted: March 03, 2009 at 2:01 PM
oh and i'm currently running the 10w7 right now
Posted By: soundnsecurity
Date Posted: March 03, 2009 at 6:30 PM
personally i like the W7s, really nice subs. but with the right box, the 2 W6s should be louder. i say "should" because you never really know when you compare to a W7 of any size. i used to run a single 8W7 in a ported box i built myself and that little sucker hit hard. most people that heard it would swear they were listening to at least 1 good 12
Date Posted: March 03, 2009 at 11:55 PM
the issue is, i'm currently running the 10w7 with a sealed box and the SPL doesn't seem all that impressive, i'm scared to go with a ported box as i've run a 12w6 in a ported box, which is known to be a big mistake. just wondering if i should go with a ported box on my 10w7 or go with two 12w6's
Date Posted: March 04, 2009 at 9:36 AM
theres nothing wrong with putting a W6 in a ported box as long as its done right. ANY sub that is not used with a box that is built for it runs the risk of sounding like poopy. same goes for a W7, sealed or ported, if it is used in a poorly designed box it will sound horrible. the 8W7 i mentioned i had, at first i had it in a sealed box that i just threw together and it was way too big because i was planning on making it ported, but i got lazy so i ditched the port. it sounded really bad, wasn't loud at all. so then i built a ported box for it and the difference was like night and day. so if it was me in your position, i would try out a ported box built to spec for your W7. and then if you dont like it, try something else, but in the end noone can tell you what will sound better to you
Date Posted: March 04, 2009 at 11:13 AM
with my prior w6, i used a ported box built to jl specs, and as you would say, it sounded poopy.
Date Posted: March 04, 2009 at 3:17 PM
manufacturer specs are usually not that good anyway, thats why it pays to try and learn a few things about enclosure design instead of taking everyone's advice at face value because like i said, only you know what sounds good to you
Date Posted: March 09, 2009 at 1:06 PM
my circuit breaker failed and i blew my 10w7 :(
Posted By: j.reed
Date Posted: March 09, 2009 at 4:32 PM
Thats why i still prefer ANL fuses over circuit breakers. If to much amperage is put through an ANL it has no choice but to fail and by doing so it is doing its job. -------------
Date Posted: March 09, 2009 at 4:59 PM
..yeah, just picked up a jl anl fuse holder..
Date Posted: March 09, 2009 at 5:43 PM
that blows, what amp were you using? -------------
Posted By: aznboi3644
Date Posted: March 10, 2009 at 7:16 PM
A circuit breaking failing would have nothing to do with a subwoofer blowing. It's called "User Error"
A circuit breaker is either "on" or "off". It lets current pass. How would that affect a subwoofer? ------------- Custom Enclosure Design
