subs and amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112294
Printed Date: April 09, 2026 at 10:35 PM
Topic: subs and amp
Posted By: jmaz268
Subject: subs and amp
Date Posted: March 12, 2009 at 1:43 AM
I have a Kicker ZX 750.1.
I was thinking of getting a pair of Kicker Comp VR 10".   Will it matter if i get the 2 ohm or 4 ohm DVC's?  Can I hook them both up and run 2 ohm successfully?
I am completely ignorant when it actually comes to the wiring of subs.  So please, any Diagrams would be extrememly helpful.  And I may even name my first born after you.
-John
Posted By: jmaz268
Date Posted: March 12, 2009 at 2:52 AM
Also the thought of PolyFill came up.
Now i see a small problem.  My subs fire down.  so obvioudly having loose polyfill laying on the subs will probably be a bad idea.  What kind of glue do people usually use to keep it stuck good.  From my knowledge poly-fill is a plastic derivitive, so some glues would just melt the fill.  just looking for alternatives.
Also I am in Afghanistan at the moment so it makes it hard to look for stuff right now.  Just a justification to my needyness ;)
Posted By: i am an idiot
Date Posted: March 12, 2009 at 5:53 AM
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
posted_image
You must get the Dual 2 ohm drivers.   If you ge the dual 4s your choices will be 1 ohm or 4 ohms.     As for the retention of the polyfill, go to the Home Depot and get some chicken wire or some metal screen door material.  Place the polyfill in the box, set the screen into the box and shape the screen in a manner that it will stay off of the woofer, then put the front on the box and insert woofers.
Posted By: jmaz268
Date Posted: March 12, 2009 at 7:36 AM
wow I thought i was good at inginuity wise things.  Good stuff.
Thanks for the awesome info.
