remote on factory amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11241
Printed Date: May 16, 2026 at 5:31 PM
Topic: remote on factory amp
Posted By: donkason
Subject: remote on factory amp
Date Posted: March 21, 2003 at 6:52 PM
I have a 1997 chevrolet camaro RS. I am hooking up my amps for my after market system and want to know if anybody knows what color the "remote turn on" wire is. Also is there a switched 12 volt ignition wire in this cluster. This would save some time as an alternative to pulling out my c.d. player to hunt them down. The amp is mounted in the right rear quarter panel near the spare tire. There is a wire cluster running into it and it would take forever to check each one with a volt ohm meter.
Posted By: Velocity Motors
Date Posted: March 22, 2003 at 12:01 AM
The PINK wire is the power antenna wire you can use it for the remote turn on lead. Otherwise you can use the ORANGE wire as well. This is the switched IGN wire.
------------- Jeff
