repairing an amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112626
Printed Date: March 30, 2026 at 3:13 AM
Topic: repairing an amp
Posted By: draggindakota
Subject: repairing an amp
Date Posted: March 24, 2009 at 3:00 PM
My buddy has a Soundstream Rubicon 500 and one of the coils (the bigger one) has broken leads where it attaches to the board (and one of the coil wraps has a break in it).
I've fixed some electronics before, so I was going to give his a shot. The main problem is my 30 watt iron doesn't seem o heat up the coil wires. The board is getting hot, but not the wires I'm touching. Can I even resolder the leads or shoudl I just get a replacement coil? And where would I find the specs on it? Thanks.
Date Posted: March 25, 2009 at 8:14 AM
Well I got the leads soldered. Had to use 2 30 watt irons to heat the leads, and then the solder flowed great. Haven't tested it yet though.
