rubber , ground?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112775
Printed Date: April 30, 2026 at 8:32 AM
Topic: rubber , ground?
Posted By: rfhvhtoo
Subject: rubber , ground?
Date Posted: March 29, 2009 at 8:43 PM
Hey I drive a ford truck and theres not many grounding areas. Some of my amps have malfunctioned so Im gonna change some things including my ground. theres a 3/4 inch screw that I think Goes all the way through to the frame and its surrounded by metal. But under the truck there is a rubber clump on the screw. Will this hurt the ground?
I can't hear you!
Posted By: calijtee1
Date Posted: April 03, 2009 at 8:42 AM
what year ford?, did you use a brush to remove the paint. where you grounded it before. ford is still made really well,.i have had this problem before too. i just used any part of the floor. just use a brush to remove the paint away because ford puts on quite a few coats .
installers do it best. we got the magic hands!
Posted By: soundnsecurity
Date Posted: April 03, 2009 at 8:51 AM
what truck exactly and where is the amp going?
Posted By: rfhvhtoo
Date Posted: April 03, 2009 at 9:48 AM
its going in a Ford F150 2006 Extended cab behind the the back seat.
I can't hear you!
