port on side instead of middle?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113003
Printed Date: April 29, 2026 at 3:17 PM
Topic: port on side instead of middle?
Posted By: whitemike0110
Subject: port on side instead of middle?
Date Posted: April 09, 2009 at 1:01 AM
I'm going to build a box for two 10's would it be okay to have the port on the side instead of the middle?
Posted By: i am an idiot
Date Posted: April 09, 2009 at 4:29 AM
Yes
Posted By: j.reed
Date Posted: April 10, 2009 at 8:03 AM
As i am an idiot said. Yes it will be fine. One thing to keep in mind is that you should have as much space as the port width or a bit more away from a solid wall. So if the port is smashed up against a wall of the vehical you can expect a performance issue. If say your port is 3 inches wide and it is at least 3 inches or more from a vehical wall you will be fine in doing this.
posted_image
Posted By: bwhvac065@aol.c
Date Posted: April 13, 2009 at 8:17 AM
i have 6 12s on a single port crammed up next to a rear window and guess what ...... It sounds like s%$t big time just do your self a favor and calculate wisley
Blazerspl
6 rockford 12s
5500 watt pa amp
12.0 cubic enclosure
BIG 3
Posted By: mdoffroad
Date Posted: April 14, 2009 at 9:59 AM
I usualy go for the longer and larger ports for less wind noise, mine usualy HAVE to vent on the side but the last poster is correct, keep it away from things DIRECTLY next to it
Matt
