2006 audi a3 no antenna reception
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113395
Printed Date: April 30, 2026 at 5:29 AM
Topic: 2006 audi a3 no antenna reception
Posted By: absolutepower
Subject: 2006 audi a3 no antenna reception
Date Posted: April 24, 2009 at 9:25 PM
getting complete audio through cd and usb. everything wired correctly and using vw10 antenna adapter which metra calls for still no am fm
Date Posted: April 24, 2009 at 9:26 PM
the sooner i get a reply the better
Posted By: i am an idiot
Date Posted: April 24, 2009 at 9:33 PM
Does that vehicle have an amplified antenna that gets it's power through the power antenna lead? Is there a blue wire on the antenna adapter? Have you tried an aftermarket antenna just to make sure your radio is working?
Quick enough?
Date Posted: April 24, 2009 at 9:55 PM
yes sir. and no i didnt try the amplified anntenna. but i will get on it. thanks
Posted By: djfearny2
Date Posted: April 25, 2009 at 7:38 AM
yea some of these cars need the amplified antenna adapter, however some that say they do need it actually work worse with them and call for a normal antenna adapter. plus depending on the car.it might have two similar slots on the plug that plugs into the radio,. the anteanna adapter will for sure plug into one and lock, But what i have also found is the second one makes it work better, In order to use that one just cut off the tab on the tip of the antenna adapter then it will slide into the second hole.
tape it up and your good to go.
Jon
Installer/Help Technician
---coral springs florida---
