04 nissan titan, airbag light, peswix
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113441
Printed Date: March 26, 2026 at 10:25 AM
Topic: 04 nissan titan, airbag light, peswix
Posted By: boosted1
Subject: 04 nissan titan, airbag light, peswix
Date Posted: April 27, 2009 at 12:53 AM
hi all i have a guy with a nissan titan 04 with the factory deck that i replaced with a double din and molded it in to look bone factory, BUT 2 things i need help with all of the sudden the air bad light blinks in the dash by the speed gauge, i tried to reset it by unplugging the batt but nothing the second issue that im having is im installing the peswix unit to integrate the steering wheel controls to the new deck but on their site they say to tap the white wire on the unit into a pin #19 wire lol there is no plug with that many pins in it there are 2 plugs that came out of the back of the stock deck and got hooked up to the adapters and then the new deck harness so im way lost on where to tap that white wire into? whats a good location for mounting that remote led so that they are in good sight with the new deck for the remote signal?
thank you in advance
slawek
boosted1@yahoo.com
Posted By: i am an idiot
Date Posted: April 27, 2009 at 6:33 AM
Posted By: KPierson
Date Posted: April 27, 2009 at 8:57 AM
Here is the wiring diagram for the vehicle:
https://www.nicoclub.com/FSM/titan/2004/av.pdf
Without knowing the trim level of the vehicle I can't offer any specific advice - there are three different levels from the looks of the factory manual.
Kevin Pierson
Posted By: boosted1
Date Posted: April 27, 2009 at 2:03 PM
the trim of the nissan titan is LE it does have a jbl sound system in it also where would you think to put the led for the signal?
