rca and multi channel amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114218
Printed Date: April 11, 2026 at 1:51 AM
Topic: rca and multi channel amp
Posted By: tsaeb
Subject: rca and multi channel amp
Date Posted: June 04, 2009 at 11:59 AM
Hello everyone
I'm looking for a good article to help me understand rca with mutichannel
Amps......been reading and searching however still have many questions
I have a 2000 impala ls and trying to install a nice system with what I have
12" solo baric 4ohms dvc sub
2 mephis 6" round front speakers 55rms
Vibe 430 amp
Mtx thunder 2300x
I wanted to install only only the vibe amp...however I've been told I can't
Bridge 2 channles and then have the other two running in stero...
I want to understand this more
Second I know 4 channels means 4 rca cables....however i see some
People only have to rcas and then add splitters
Hoever I could of swear I when I had my vibe installed in my truck (by a pro)
With to 6x9 and two 10"s it only had two rca cable huck up to it
So this is where I don't understand rcas? How many rcas do I need?
What's the diff between 4 rcas and two rcas with splitters? And can I or why can't
I bridge two channels on a 4 channel amp and huck up the other two channels
Normally?
I know that's a lot guys this is why I'm looking for an artilce....any help is great
....thanks guys.
Posted By: icearrow6
Date Posted: June 04, 2009 at 12:17 PM
1. Yes, your amplifier can be bridged. But it can only produce 200W bridged to your sub (8 ohm load). (Dual voice coil in series).
2. On your amp you must use 4 RCa's. use a splitter.
Posted By: tsaeb
Date Posted: June 04, 2009 at 5:18 PM
ok so. For example is it possible to put the mephis speakers indivisually to
A channel 1 and 2.....and then bridge 3 and 4 to my 4 ohms dvc
Sub? I know "just put two amps" yeah I would like to save the mephis for my
Truck
I emailed crunchfield and they said no I lost the mail
However the said something about rca signal being shared.
And why do u say 8ohms.... I thought since its a dual voice 4
Ohms I can huck it up. 2 .... 4.... or 8 so this means I can see
400 rms max if I bridge it at 4ohms (hucking up only one coil)
The specs for the vibe are.
4 x 125 w rms @ 4ohms
4 x 200 w rms @ 2 ohms
2 x 400 w rms @ 4 ohms bridged
Posted By: tsaeb
Date Posted: June 04, 2009 at 5:33 PM
Sorry I meant save the mtx 2 channel amp for the truck not the mephis
Posted By: i am an idiot
Date Posted: June 04, 2009 at 7:59 PM
You can bridge 2 channels and have the other 2 running in stereo.
