amp location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114219
Printed Date: April 10, 2026 at 9:54 PM
Topic: amp location
Posted By: i_want_the_boom
Subject: amp location
Date Posted: June 04, 2009 at 12:38 PM
Is it ok to mount the amp to the speaker box? i've done it before and i seen alot of installs done that way, i was just wondering if its not good for the amp or is it ok. does it matter if its on the back, the side or the top does it make a difference. i have never had any problems doing it this way but i read somewhere that it could mess up your amp.
If the trunk dont rattle then its not loud.
If it's to loud then you're to old.
Posted By: bigrank916
Date Posted: June 04, 2009 at 12:42 PM
I did it once and wouldnt do it again. It rattled my cap remote wire screw loose. I had to open it to fix it. The amp still works but I hope nothin got damaged. I would put it somewhere else.
Posted By: joch1314
Date Posted: June 04, 2009 at 12:51 PM
I agree...it's a DEAD last resort for mounting.  think about it! if you ever have to remove the box you'd have to disconnect the amp...becomes a pain!  find another spot.  what kind of vehicle....make /model!  we can give you some options if you're having trouble finding a spot.
...half of the truth can be worse than a lie. <----Roger Russell said that..
Date Posted: June 04, 2009 at 12:56 PM
I have a 93 chevy caprice i have lots of room in the trunk. if i were to take out the spare and make an amp rack how would i secure it to the car?
Date Posted: June 04, 2009 at 1:28 PM
A long time ago I used a board with carpet and just laid it on the trunk floor. With carpet agaisnt carpet it shouldnt move too much. Or just use some brackets. I wouldnt take out the spare tire for a stereo system unless the car is comp. U would look like a dufuss with a flat tire on the roadside w/o a spare cause your stereo is so dope.
