nissan sunny 2006 audio system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114255
Printed Date: April 09, 2026 at 6:25 PM
Topic: nissan sunny 2006 audio system
Posted By: manaa
Subject: nissan sunny 2006 audio system
Date Posted: June 05, 2009 at 1:14 PM
hi
i have a 2006 nissan sunny with an old audio system (original one ) with tape reader! and i want to change it with a pioneer cd mp3 reader. can some help me in the procedure of dismantling original system from the kick panel. and i have also a question : is there any space problème in installing this system.
thank you in advance for any help.
Posted By: t&t tech
Date Posted: June 05, 2009 at 4:22 PM
with the top panel's pocket open, grip the interior with both hands and pull gently toward you the panel will snap off, the bottom there are two finishes one snaps off as you pull towards you like the top panel, the other will require you remove the panel at the gear shifter which will the expose four screws in total remove all four and voila.
Posted By: t&t tech
Date Posted: June 05, 2009 at 4:35 PM
the wiring at the top of my head
blue- twelve volts
pink- accesory
BLACK/ white- antenna
front speaker brown and brown white and GREEN/ YELLOW and purple, the rear speakers are on a separate connector right next to the main connector, test with a battery to verify polarity and location.
Posted By: t&t tech
Date Posted: June 05, 2009 at 4:38 PM
oh and no problems with mounting space in this car pioneer fits right in, if you wonder why i'm posting all this separately it's because all my posts aren't being submitted and i don't wanna write a long story and it doesn't get submitted and i have to came back and do it all again like i've been doing for the past half hour trying to post the above info. posted_image
Posted By: manaa
Date Posted: June 05, 2009 at 4:46 PM
thank you very much t&t tech, i'l try to do it this week-end.
an other question : for the connectors on the car , do i need to change them because on the pioneer there is only 2 standard connectors : one for power supply and the second for speekers
Posted By: t&t tech
Date Posted: June 05, 2009 at 5:29 PM
if you don't have the wiring harness kit for it you can either tap onto the existing connections in the event you would like to re-install the original radio or you can just cut off the connectors completely, the choice is yours, of course the wiring kit makes life alot easier, jus so you know. cheers.
Posted By: manaa
Date Posted: June 06, 2009 at 2:39 AM
thank you again t&t tech , i think i will try the first solution, keeping the original installation as you said in the event of reinstalling the original radio.
i will do this soon.
thank you again for the reply.
