hi fonics cupid
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114273
Printed Date: April 09, 2026 at 3:52 AM
Topic: hi fonics cupid
Posted By: dablack
Subject: hi fonics cupid
Date Posted: June 06, 2009 at 3:16 PM
does anyone know what the colors represent for the wiring harness for this amp..or better yet what color is the remote for this
Many thanks in advance
Posted By: i am an idiot
Date Posted: June 06, 2009 at 3:50 PM
What are the colors of the wires you have?   Is it a 1 or a 2 channel amp?  If there is an Orange wire, chances are that will be the remote wire.  If it is a 1 channel amp, Violet is positive and Grey is negative.  If it is a 2 channel, violet is left positive.  Grey is right negative, these 2 are the bridge wires.  The other 2 wires are connected together inside the amp, one is left negative and the other is right positive.  It does not matter which wire you use for which channel.
If memory serves me right, green is left negative.  Brown is right positive.
Posted By: dablack
Date Posted: June 06, 2009 at 3:55 PM
green,grey at bottom...... brown,orange,purple on top (label of amp as top side)
Date Posted: June 06, 2009 at 4:03 PM
Looking at the amp, with the 3 pins on top.  Bottom row are negative.  Top row is all positive.  Center pin is remote.   Left side is left channel   right side is right channel.  Bridge is Left top and right bottom.   That is looking at the amp not the plug.
Notice in this picture the green and brown wires are connected together. Also notice that the Violet and Grey wires are connected to the output transistors. The orange wire connects directly to the Pulse Width Modulator IC of the power supply.
https://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm   At the very bottom of this page is a diagram of your plug.  It has the wire colors and all.
