speed sensitive volume control
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114313
Printed Date: April 29, 2026 at 8:10 AM
Topic: speed sensitive volume control
Posted By: MvDixon03
Subject: speed sensitive volume control
Date Posted: June 08, 2009 at 11:22 AM
I'm sure many of you have installed several head units that utilize the Speed sensitive volume control feature that increases the head units db as the vehicle speeds up in order to drown out road noise, as have I. However in most basic installs it is pre-wired in the factory harness (as its a factory feature). Now however I am doing a custom build from the ground up for a trike manufacturing company, and recently they want to utilze this feature in their trikes. So what exactly produces this signal that is supplied to the head unit for the speed sensitive volume control; Vehicle Speed Sensor, Tach signal, some sort of computer module...??? and how could I obtain this signal in a vehicle with no computer?
Thanks,
-Dixon
Posted By: soundnsecurity
Date Posted: June 08, 2009 at 10:50 PM
pulses generated by a sensor somewhere on the wheels. one rotation, one pulse, the faster you go the more pulses per minute you get. thats pretty much how it goes. to interface something like this to a radio with that feature you would first need to know exactly what the radio needs to see to raise and lower the volume which would probably require a call to the manufacturer tech department. and then you need a sensor that will generate the right amount of pulses per turn of the wheel, maybe an optical sensor with a small mirror mounted in the wheel or maybe use the chrome wheel as the mirror and have a small non-reflective dot that the sensor would read as one turn.
i wouldn't use any kind of tach signal because engine RPM doesn't necessarily translate into speed. the radio would just go up and down as you rev the engine and wouldn't be much help when you cruise at low rpm.
Posted By: KPierson
Date Posted: June 08, 2009 at 11:16 PM
From what I have seen they either use an ABS sensor (which is 30+ pulses per 1 wheel revolution) or a sensor mounted on the transmission output shaft.
I, personally, have never seen a dedicated sensor for this feature, they basically just pick up a VSS signal that is already installed for other purposes (like ABS) and reuse it.
If I were going to add this to a vehicle I would definately go with the output shaft of the tranny.  You cand do a single pulse per revolution and it should work great.  You would then need a controller to turn the frequency that the output shaft is spinning at in to a something that the radio (or amp) can use to turn up the volume.
What kind of radio are you installing?
Kevin Pierson
Date Posted: June 09, 2009 at 8:24 AM
Currently we are using poineer premier, Sony, and JBL marine headunits, but I'm yet to recieve the brand specific info from the manufacturer, for this trike... I think it may depend on whether we can utilize this speed sensitive volume control or not. I am very familiar with the VSS shaft off of the tranny (We use 700R tranny's with a small block 350 setup) So I already have two types of pulse generators coming off of the shaft, one for the speedo (uses an inductive magneto to generate its own signal), and an auxilary VSS (that requires a 12V supply) to send signal to the Cruise control unit. So if I'm understanding this correctly... I should be able to either use a signal from one of my current generators, in which I'll need some sort of converter for the signal since the Speedo and Cruise for my specific setup require an 8000 pulse (per mile) generator setting? Or I'll need to add another auxilary VSS to the shaft dedicated solely to the radio, and still possibly need a converter for the signal to appropriate the frequiency dependent on which ever headunit we decide on? Also is there a technical name for this frequency converter, or will the audio manufacturer know what I'm talking about when obtaining the specs from them?
-Dixon
Posted By: KPierson
Date Posted: June 09, 2009 at 10:28 AM
I would think that one of your existing signals can be used to work.  If your radio already has a VSS input on it you won't need any converter at all you should be able to hook it directly to the current VSS wire and be done with it..  If you are trying to add a VSS sensitive feature to a radio that doesn't have it you will need a converter (and a bit more circuitry) to convert/interpret speed and provide the necesarry output to adjust volume.
Kevin Pierson
