clarion shows amp ground
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114440
Printed Date: April 08, 2026 at 2:20 AM
Topic: clarion shows amp ground
Posted By: mysticshattaz
Subject: clarion shows amp ground
Date Posted: June 14, 2009 at 3:14 AM
i have a 2000 Nissan Altima
i installed a Clarion dxz385usb cd receiver and it worked great. but today it showed a message saying "AMP ground" what does that mean? n how can i fix this issue.
posted_image
Azhar
Posted By: i am an idiot
Date Posted: June 14, 2009 at 6:49 AM
Check for grounded speaker wires.  (Of the speaker wires connected to the radio.  Not of an outboard amplifier)  Did you recently change any of your speakers?  If so make sure the terminals of those speakers are not touching metal.   Disconnect all speakers from radio and connect them back one speaker at a time.  Connect one, turn the radio on and see if the message is there.  Keep connecting speakers and turning deck on until the message reappears.  Then you will know which speaker wire is the problem.
If you have an ohm meter and would rather use that, simply unplug the harness from the back of the radio and check each wire for a short to ground.
Date Posted: June 14, 2009 at 2:30 PM
thanks it worked!
my trunk spring was touching the speaker harness so it shorted it out :x
but thank u again =)
Azhar
