clarion or alpine?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114454
Printed Date: April 08, 2026 at 5:59 PM
Topic: clarion or alpine?
Posted By: sublinux
Subject: clarion or alpine?
Date Posted: June 14, 2009 at 6:30 PM
What is the best for the price / SQ in a ported 10" 1.4 cu.ft at 40 Hz amplified by a Pioneer GM-D7400M 250 watts RMS at 4ohms.
Clarion SW1051 or Alpine Type-E SWE-1043 ? Both are around 100$.
Posted By: ianarian
Date Posted: June 14, 2009 at 11:06 PM
Huh...good question. Opiniarian: Alpine works well ported, but usually not in reference to SQ. Ports need power. Either way you go, I cant imagine that you would ever believe you chose wrong. If your not happy with your choice you may want to look again at your amp/box type combo.
This is what I do for FUN!
Posted By: sublinux
Date Posted: June 15, 2009 at 11:32 AM
Well right now i have the Clarion and its underpowered.. Spec said that it can support up to 375 watts RMS... my amp can shoot only 250 Watts.. So with the alpine it wont be underpowered... But maybe going with a 2 Ohms SVC or 4 Ohms DVC so i can have 400 Watts rms.
Posted By: ianarian
Date Posted: June 18, 2009 at 8:41 AM
Pioneer plays clean but I never got the high output feeling from them. Electronic crossover comes to mind. Id probably crank up the input voltage and see what the amp could do. * thinking out loud. *
The 2 ohm dvc idea might be worth it.
