audio noob asking multi channel?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114501
Printed Date: April 27, 2026 at 5:31 PM
Topic: audio noob asking multi channel?
Posted By: remerone
Subject: audio noob asking multi channel?
Date Posted: June 16, 2009 at 6:24 PM
This is what I have connected:
-Two 'the Punch' 10" subs
-Rockford-Fos 500amp
(so its just the subs connected to the amp and speakers to head unit)
Okay so my rear speakers are popping does that mean I have to connect my rear speakers to a mutlichannel amp? I have a Directed 650 amp [5 channel] laying around and also a Farenheit PowerAcoustik amp laying around, 4 channel(sorry cant read the amps on this one..)
What should I do? Are these amps uneccesary to fix my problem.
P.s. I dont know squat about car audio!
Posted By: i am an idiot
Date Posted: June 16, 2009 at 7:53 PM
Since I hace no idea what kind of vehicle we are dealing with, I will grasp at a few straws.  If you open the trunk of the car, do the speakers still pop?  If you turn the subs off, do the speakers still pop?   If your subs are firing straight up and directly toward the popping speakers, turn the box so the subs fire toward the back of the car.  If you have a truck pretty much disregard all of the above, and let me know what you are driving.
Posted By: remerone
Date Posted: June 16, 2009 at 9:50 PM
they start popping when the volume on my head unit is about three 3/4 the maximum or they cut out and only the subs play...ive never messed with the crossover frequency on my amp. Every single wire is in correct place. Im 100% sure. I just dont know about ohms and crossovers and stuff?
I drive a 2002 Honda Civic Ex.
Rear speakers are JBL's and front speakers are stock..
Date Posted: June 16, 2009 at 10:50 PM
A different approach!!!
How loud do you have to turn the volume on the radio to make them pop?
Do they sometimes cut out all the way and just leave your woofers playing alone?
Have you ever messed with the crossover frequency of your amp?
Is every wire of your system in it's correct place?  Are you sure?
What do you know about Ohms and crossovers and stuff?
What kind of speakers do you have?
If you open the trunk, do the speakers still pop?
If you turn the woofers off, do the speakers still pop?
Posted By: haemphyst
Date Posted: June 16, 2009 at 11:08 PM
That's funny... posted_image
Posted By: lil evo
Date Posted: June 17, 2009 at 9:38 AM
I would guess, wiithout hearing the problem for myself, that you've got at least one bad rear speaker. When they hit a certain volume, they'll start popping. Drive them a little harder, speakers cut out all together and you have just your woofer playing. This is because part of the speaker is coming into contact with a ground and throwing the source unit into protect mode. If the symptoms I've specualted are correct, try replacing your rear speakers and check back with us.
