dual 2ohm vs dual 4ohm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114541
Printed Date: April 28, 2026 at 12:27 AM
Topic: dual 2ohm vs dual 4ohm
Posted By: spmpdr
Subject: dual 2ohm vs dual 4ohm
Date Posted: June 18, 2009 at 1:15 PM
how much of a sound/ power difference would there be in these different types of sub wiring setups:
Option 2 (series/parallel) = 4 ohm load
Option 2 (series/parallel) = 2 ohm load
I am asking becuase Ijust got new subs and they are dual 4ohms I asked for the dual 2ohms.anyway I want to know the advantages / disadvantges of dual 2ohm vs. dual 4ohm. they are 2 12" re audiosr12d4 they would be ran mono to a 500 wattrms memphis monoblock. thnak you
-A vision without a plan is just a hallucination-
Posted By: DYohn
Date Posted: June 18, 2009 at 7:22 PM
Wire them in whatever way is correct for your amplifier.  What is the lowest impedance the amp can sustain?
Posted By: stevdart
Date Posted: June 18, 2009 at 8:04 PM
You should insist on getting your order the way you wanted and run the two DVC 2's at a 2 ohm impedance.  Don't jeopardize your amplifier's life expectancy because of someone else's mistake.  Further, in reference to your question, the DVC 4's would be the choice if your amp was a two-channel rather than a mono (run at 2 ohms/channel).  Or, if you wanted to max a capably-rated mono amp with a 1 ohm load.
