jl audio, buick century
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114549
Printed Date: April 27, 2026 at 4:46 PM
Topic: jl audio, buick century
Posted By: ac3xk1ng
Subject: jl audio, buick century
Date Posted: June 18, 2009 at 7:18 PM
Hi, I have a 1999 Buick Century.
My cousin just gave me 2 JL Audio 12'', and 2 JL Audio 10'' subs. He also gave me a 760w pioneer amp. So far, I have an alpine deck that I have not yet installed. Best Enclosure type and where to get it, new amp?, and how to install the deck would all be great info if someone can help. Thank you very much!
99' Buick Century
Posted By: tommy...
Date Posted: June 18, 2009 at 10:22 PM
I know you can get vehicle specific/sub specific boxes! Yes on the new amp...(price range?)....Whats the actual model of the subs(other then jl)...You will need a mounting kit, harness and antenna adapter...Part # 99-2003(mounting kit)...70-2001(harness)...40gm10(antenna adapter...Heres how to take radio out...and worst case scenario...You can temporarily use the amp...Whats the actual model # on the amp...?
1. Open both doors and remove end caps from both ends of dashboard.
2. Open glove box, then remove (1) 9/32" screw from panel above passenge
kick panel and remove.
3. Remove 9/32" screws from bottom left and right of ashtray assembly
and unclip and remove.
4. Unclip top edge of panel below steering column and let hang.
5. Remove (1) 9/32" screw from right side of instrument cluster and
radio trimpanel and remove entire panel from right to left.
6. Remove (3) 9/32" screws to remove radio.
M.E.C.P & First-Class
Posted By: tommy...
Date Posted: June 18, 2009 at 10:27 PM
You can check out your local install shop for a custom enclosure(expensive) or Audio Enhancers for a little less
Posted By: ac3xk1ng
Date Posted: June 19, 2009 at 10:44 AM
Thank you and thank you! Um, I dont know the model number of the subs off the top of my head but i will let you know asap. What size amp is best for 2 subs? Im new at all this so im very sorry for all the questions. But, Your help is greatly appreciated.
99' Buick Century
Posted By: ac3xk1ng
Date Posted: June 19, 2009 at 4:33 PM
The subs are wO's
99' Buick Century
Posted By: tommy...
Date Posted: June 19, 2009 at 4:39 PM
Your Welcome and Your Welcome...The subs should have the Model # on side or bottom...Also can you list the amp's Model #...?  Will match you up an amp (price range?) when you can get info on subs...!
Posted By: ac3xk1ng
Date Posted: June 22, 2009 at 6:45 PM
Alright so the subs are wO's, my cousin told me that, the subs are currently in a box and i don't wanna mess anything up yet. The box doesn't fit in my trunk, thats where i'm having the issue. The amp is a pioneer 760w 2 Channel Bridgeable Gm-5000t.
99' Buick Century
Posted By: ianarian
Date Posted: June 22, 2009 at 8:33 PM
Opiniarian: Use the pioneer amp for highs. Go to every shop in your area and bargain with them. Every shop wants business and smart owners will always work with you. Once you trust the shop owner, patronize him for your needs. Post his ideas and prices here and we'll tell you if its a good deal. Port your subs into the cab. DO NOT let your trunk rattle. Rattlers SUCK!
This is what I do for FUN!
