adding a amp to Bose system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11457
Printed Date: March 31, 2026 at 8:16 PM
Topic: adding a amp to Bose system
Posted By: brianh
Subject: adding a amp to Bose system
Date Posted: March 25, 2003 at 8:06 PM
I did this the other day and everything worked fine but there was no bass. Is it possible that I connected the input wires to a crossed over speaker wire in the Bose system? If so does anyone know the colors of the wires that I need or where I can find them? The vehicle is a 1997 Nissan Maxima. Thanks in advance. Brian
Posted By: esmith69
Date Posted: March 25, 2003 at 9:55 PM
Were you trying to do a 4-channel amp with the factory speakers?  Or was it a 2 or 1 channel amp for subs?
It is possible that you tapped in to a wire that only goes to the woofers in the system.  I've never known the bose systems to do this but I know for example the ford mach 460 system has two amps in the back that run all 6 woofers in the system, and then one other amp in the dash that runs the highs for all the speakers.
