not loud enough for me
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114701
Printed Date: April 18, 2026 at 2:16 PM
Topic: not loud enough for me
Posted By: imupabove
Subject: not loud enough for me
Date Posted: June 26, 2009 at 1:19 AM
Car: 93` Toyota Camry LE
Audio: Alpine IDA-X200, Infinity 6022's, Alpine SPS-609's, Kenwood KAC-8104, 4 Gauge Wiring, 12" Alpine Type-R(All 14 Gauge speaker wire)+Ported box tuned @ 38 Hz (Pre-fab).
For the amp, I have the LPF on 100, Gain set at 3/4 (0.5), Bass is set to the max. ISF at 25 Hz. For the headunit, I have the subwoofer volume to the max. Treble to the max. Bass at -5, 200 Hz and 4 wide. HPF is at 120 Hz. Loud is Off. Fader/Balance ar equal. For the box, its a pre-fab that I bought on Ebay. If you can please go on Ebay and copy paste this item number: 170347628466 (since Ebay links don't work :p).
I'm think do I need a stronger amp? build a ported custom enclosure? Or am I missing something? Or maybe I'm going def, LOL. Well I'm pretty my setup has potential, and sure I'm missing something. Any honest help will work, I'd appreciate it. Thank you for your time.
Posted By: haemphyst
Date Posted: June 26, 2009 at 9:05 AM
IMO, and... based on what appears to be your desired goal, that's NOT the right box for you... Tuned a bit low, and I'm also thinking that one of THAT particular woofer isn't going to meet your goals.
Again, IMO, you need a woofer more aimed at SPL. While the Rs are not what I would call an SQ woofer in the strictest sense of the word, they aren't meant for the outputs I think you want, especially when running solo.
Posted By: silent4408
Date Posted: June 26, 2009 at 9:22 AM
most importantly. type R subs nee power, at least 500 rms and that little kenwood will never get that sub moving like u want it to. i didnt check out the box but going with a custom box built to the spec of the subs is always the best idea, especially when u are doing a nonsealed box. and tune it up a bit..above 50 would sound best.
"JT" Advanced Certified installer for Sound Sensations in Marietta,GA
Posted By: soundnsecurity
Date Posted: June 26, 2009 at 9:30 AM
above 50hz? i hope he only listens to tones. above 50 is good for one note competition boxes but uuuuh i wouldn't go there if you want to hear decent quality with music. but i DO agree with getting a new box made. what is the cubic footage of your prefab box?
Posted By: DYohn
Date Posted: June 26, 2009 at 9:46 AM
I agree the pre-fab enclosure is part of the issue.  Is your sub a 1242 or a 1222?  How do you have it wired?  Also please try this: set your bass and treble controls to +1 or +2.  Make sure your sub is set to SYS1.  Set the HPF to 80Hz.  On the amp, set the bass boost to zero and then follow these instructions to set your gain: https://www.the12volt.com/installbay/forum_posts.asp~TID~85479~PN~1  Report back when you are done.
Date Posted: June 26, 2009 at 11:27 AM
around 1.9 cu. ft.
Date Posted: June 26, 2009 at 5:27 PM
imupabove wrote:
around 1.9 cu. ft.
is that with or without the port volume included? i would make it a little bit bigger, maybe 2.4 plus whatever the port is
Date Posted: June 26, 2009 at 7:09 PM
umm. i dont know. i just used the volume calculator on here. i used the rectangular/squared enclosures.
Date Posted: June 26, 2009 at 7:26 PM
ok so your 1.9 includes the port which means that it is probably closer to 1.5 cubic feet if you subtract the port. that is about what alpine recommends for a ported enclosure so i would give it about another half a cubic foot and tune your port low
Date Posted: June 26, 2009 at 8:51 PM
Not if he wants output... You tune high for SPL, say somewhere in the 42-45Hz range. He's already tuned too low, which is why his output suffers so drastically.
Date Posted: June 26, 2009 at 9:48 PM
lol. im the kind of person that if my bass isnt heard from at least a block i dont even play my music loud. so what should i do?
Date Posted: June 27, 2009 at 9:51 AM
yeah you're right. i dont know what i was thinking. tune in the mid 40hz range but i wouldn't go higher than 50hz because you listen to a lot of rap/hip hop
