wire color codes for 1990 nissan pulsar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114743
Printed Date: April 25, 2026 at 5:18 PM
Topic: wire color codes for 1990 nissan pulsar
Posted By: brioreos
Subject: wire color codes for 1990 nissan pulsar
Date Posted: June 28, 2009 at 3:29 PM
I've found stereo wire color codes for 86-89 and then 91-93 but there's none for the 1990 model. I've tried using other codes but my car doesn't have pink wires and plain green ones etc.
If anyone could help me with a diagram or anything that'd be amazing!
Thank you so much in advance.
Posted By: tommy...
Date Posted: June 28, 2009 at 4:31 PM
Are some of the colors the same in harness...Like a few BLACK/ whites...?
M.E.C.P & First-Class
Posted By: brioreos
Date Posted: June 28, 2009 at 5:06 PM
some are the same as what it's SUPPOSED to be, like RED / yellow, blue, red and brown, but mostly it's colors that aren't mentioned
Posted By: tommy...
Date Posted: June 28, 2009 at 5:53 PM
Do you have a meter...? Can you visibly see any speakers and there wires...Installdr.com list the 2 normal nissan harnesses...Either of those...?
Posted By: tommy...
Date Posted: June 28, 2009 at 6:01 PM
Is it just one solid harness...kinda looks like it would go into here w/ two slots running parallel down the middle of harness?posted_image
Posted By: brioreos
Date Posted: June 28, 2009 at 6:17 PM
Wow this looks like what I've been needing, thank you so much for your time!
If this works I'm gonna be one happy guy lol
thanks again!
Posted By: brioreos
Date Posted: June 28, 2009 at 7:44 PM
Dang didn't work...
and no it's two seperate harnesses, I found the back speakers are from one little harness and I'm pretty sure they're connected correctly but I can't tell because my deck isn't turning on.
And the other Harness should have the power and front speaker wires in it but I can't figure out which is which.
Posted By: tommy...
Date Posted: June 28, 2009 at 8:58 PM
Do the harnesses kinda look like the ones in the pic...You can always run a wire from the battery ,to the radio(at least for power)
posted_imageAPP8PIO * to pioneer14 pin plug(top one)
posted_imageAPP0121
https://forum.pulsar.org.au/showthread.php?t=66933&highlight=pulsar+radio+wiring...  Heres a pulsar forum in austrailia...
posted_image
