how to wire either 4 or 2 2ohm dvc subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114903
Printed Date: April 09, 2026 at 8:34 PM
Topic: how to wire either 4 or 2 2ohm dvc subs
Posted By: chargerondavins
Subject: how to wire either 4 or 2 2ohm dvc subs
Date Posted: July 07, 2009 at 12:39 AM
I've got 4 HCCA 12s, 2 ohm DVC subs.
I've got the D5000 orion amp... it's not able to push the 4 subs, CONSTANT problems, and 2 different amps, re-wired time and time again, and same issues arise.
Even installed in a different vehicle, and the same problems persist.
So, what should I do?
I want to either buy 2 amps that can wire the subs at 1 ohm... or 1 amp and 2 subs... at 1 ohm.
One way or another, what can I do to wire 2 ohm DVC subs to 1 ohm?
Any advice on a cheap, but good amp? The Orion SUCKS. Some brands you pay a lot for the name, I just want two amps that will put out about 2500-3000 RMS, or a way to make this set-up work... and from what I got from my other thread I assume it can't be done, and I'm done messing with it.
------------- 2006 Dodge Charger show car
2003 Ford Exploder DD
Date Posted: July 07, 2009 at 12:40 AM
also, the amp is 1 ohm stable, and a mono block. Car is a 2003 exploder.
Posted By: DYohn
Date Posted: July 07, 2009 at 8:27 AM
See the list of links to the left? See the one titled " Subwoofer Wiring Options"? ------------- Support the12volt.com
Posted By: richardparker
Date Posted: July 07, 2009 at 3:34 PM
Wire each subs coils in series to create 4 ohms out of each sub,then wire all 4 subs in parall to your mono amp.This will create a 1ohm load for your amp.
