alpine cda 7837
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115224
Printed Date: May 16, 2026 at 5:07 PM
Topic: alpine cda 7837
Posted By: 13lokei
Subject: alpine cda 7837
Date Posted: July 21, 2009 at 8:07 PM
Ok got the instal done on this Alpine 7837, however the cd player plays but with no sound. I can see the count down on the screen as it plays but has no sound. Sound is good on fm/am. Whats up with that? Thanks in advance.
Posted By: i am an idiot
Date Posted: July 21, 2009 at 8:33 PM
Connect the Blue/White wire to your amplifier's remote terminal. You connected the Blue wire of the radio. Connect the Blue/White instead.
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: 13lokei
Date Posted: July 21, 2009 at 8:37 PM
My wiring harness for the 7837 dose not have the blue / white wire. I do have that on the cars wiring. There are 3 blank spots on the 7837's wiring harness. Can I be missing that blue/white wire? The wiring harness is brand new.
Date Posted: July 21, 2009 at 8:42 PM
Yes you could be missing the wire. You can connect your amp's remote wire to the red wire of the radio. The amp will come on whenever you turn on the key. There may be a pinout diagram on the top of the radio. If blue is on the corner, directly above red, Blue/White is directly to the left of Blue ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: 13lokei
Date Posted: July 21, 2009 at 8:59 PM
ok connected the blue/white to the red. Still same problem no sound on CD mode. Maybe the Cd player is bad. I was only promised that everything worked great, maybe it isn't. Thanks
Date Posted: July 22, 2009 at 10:58 PM
Don't connect the blue/white to the red. Connect the wire that goes to the amp's remote terminal to the red wire of the radio.
Posted By: drew454u
Date Posted: July 23, 2009 at 12:30 AM
you have a bad cd player, lets put the facts out.
1. when playin the radio you have sound.
2. you change to cd mode and nothing.
Am i missin somthin?? this just sounds to me like it is malfuctioning.
Date Posted: July 23, 2009 at 6:23 AM
He has his amplifier turn on wire connected to the power antenna wire of the radio. When the tuner is on, it applies power to the power antenna wire to raise the antenna. When he listens to CD, there is no power on the power antenna wire. His amplifier is turning off. This has been a common problem since Sony started putting separate Power Antenna and Amplifier Remote wires on their radios in the early 90s. https://www.the12volt.com/installbay/forum_posts.asp?tid=24207&KW=no+sound+cd+antenna https://www.the12volt.com/installbay/forum_posts.asp?tid=12136&KW=no+sound+cd+antenna https://www.the12volt.com/installbay/forum_posts.asp?tid=3064&KW=no+sound+cd+antenna ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: 13lokei
Date Posted: July 23, 2009 at 8:50 AM
Ok this is a 1995 Jeep grand cherokee. What is the color code for the amps power wire? I have a conversion plug i bought to connect the alpine to the stock wiring harness. There is a blue / wire out of the conversion wire and i connected it to the red. You are right the power antena gose down when switched to cd mode. I think your right about the amp being off.
Posted By: 13lokei
Date Posted: July 23, 2009 at 7:01 PM
Ok your right " I am an idiot" I used the antena wire and wired it in to the red ign on wire, everything works fine now. The antena wire must be bundled with the amp power on wire. Anyways everything works fine now and I dont mind the anrena being up while on CD mode. Thanks
Date Posted: July 23, 2009 at 7:21 PM
Glad you got it working.
