speakers to amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115290
Printed Date: May 15, 2026 at 8:18 PM
Topic: speakers to amp
Posted By: dred
Subject: speakers to amp
Date Posted: July 26, 2009 at 8:42 AM
hey guys is it safe to wire 2 4ohms speakers on the same channel + to + - to-
------------- dre
Posted By: DYohn
Date Posted: July 26, 2009 at 9:18 AM
With what amp? ------------- Support the12volt.com
Posted By: dred
Date Posted: July 26, 2009 at 9:34 AM
4 channel XS 880 watt amplifier 2 ohm stable bridged
------------- dre
Posted By: i am an idiot
Date Posted: July 26, 2009 at 9:59 AM
Are the woofers single or dual voice coil? What leads you to believe the amp is stable at 2 Ohms bridged? Will it run 1 Ohm per channel? ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: DYohn
Date Posted: July 26, 2009 at 10:17 AM
XS 880? What is that, a Sony Xplode model number? Please be more specific. ------------- Support the12volt.com
Posted By: dred
Date Posted: July 26, 2009 at 10:37 AM
XS is the brand XSA-880 the model its an English amp. it 4 4ohm speaker i want to connect 2 speaker per channel how to do it. ------------- dre
Posted By: DYohn
Date Posted: July 26, 2009 at 10:57 AM
Never heard of it, and it's not a good sign when Google can't find it either. What are the amplifier specs? ------------- Support the12volt.com
Posted By: dred
Date Posted: July 26, 2009 at 12:05 PM
2ohm stable bridged,440*1 440*2 220*1 220*4 rms anti-thump, thermal protection built in fixed hi and low crossovers low at 80 high at 120hz.. Heavy Duty aluminium heat sink
------------- dre
Posted By: DYohn
Date Posted: July 26, 2009 at 12:51 PM
IF it's 2-ohm stable then sure, you can connect two 4-ohm loads in parallel. ------------- Support the12volt.com
Posted By: dred
Date Posted: July 26, 2009 at 2:14 PM
what about in series? i wanna put 2 4ohm voice coils to one channel on the amp in series how do i do that?
------------- dre
Posted By: DYohn
Date Posted: July 26, 2009 at 6:04 PM
Sure, that is not a problem. It will result in an 8-ohm load on the amplifier channel, and I don't know of a car audio amplifier that cannot handle an 8-ohm load. Why do you want to wire them in series? ------------- Support the12volt.com
Posted By: dred
Date Posted: July 26, 2009 at 6:07 PM
i wanna wire them in series because i want to power both my fronts and rears all four speakers ------------- dre
Date Posted: July 26, 2009 at 6:09 PM
Option 1 (parallel) = 2 ohm load Speakers wired in parallel Recommended Amplifier: Stable at 2 or 1 ohm mono |  | Option 2 (series) = 8 ohm load Speakers wired in series Recommended Amplifier: Stable at 4, 2, or 1 ohm mono |  |
Posted By: dred
Date Posted: July 26, 2009 at 6:11 PM
thanks a lot guys for your helppp thumbs uppp. But would my sound quality degrade with the 8ohm load
------------- dre
Posted By: DYohn
Date Posted: July 26, 2009 at 6:21 PM
Your sound quality will likely improve, but the volume level will be cut in half. You will need to re-set your gain. ------------- Support the12volt.com
Posted By: dred
Date Posted: July 26, 2009 at 6:23 PM
ok kool thanks a lot
------------- dre
