dnx9140 issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115295
Printed Date: May 15, 2026 at 6:48 PM
Topic: dnx9140 issues
Posted By: sonyw810
Subject: dnx9140 issues
Date Posted: July 26, 2009 at 3:15 PM
Installed Kenwood DNX9140 into 2008 Ford F-250.
Accessories installed: Sirus addon, and Backup cam.
Problem: Rearview camera does not display when plugged into the rearview camera input
The camera displays when pluged into other video in. I checked all wiring and all is correct.
Sorry if this is in the wrong section and thanks for any help.
Posted By: Ween
Date Posted: July 26, 2009 at 6:52 PM
hi,
did you enable the rear camera interrupt (set to on) in the A/V setup menu?
m
Posted By: i am an idiot
Date Posted: July 26, 2009 at 7:11 PM
Did you connect the reverse wire to the deck?
Posted By: sonyw810
Date Posted: July 27, 2009 at 11:56 AM
I set the interupt to on for AV but it doesn't specifically say rear view cam anywhere. I have it just ran to a video in right now and when I put it in reverse it switches to the cam but it doesn't switch away after I put it back into drive it just turns the cam off (which is what should happen)but I hoped it would switch back automatic to the previous screen
Posted By: joch1314
Date Posted: July 27, 2009 at 12:05 PM
Got into the "A/V interface" part of the setup menu and there you'll have 3 pages to select different options for what you're connecting to the deck.  The R-Cam interruption will be on the second page...set it to on and connect the camera into the r-cam input behind your deck.  To change to the second or third page you'll see an arrow next to the number "1", scroll right and you'll get the page you need.  You should be all set after that.
...half of the truth can be worse than a lie. <----Roger Russell said that..
Posted By: sonyw810
Date Posted: July 27, 2009 at 12:11 PM
Ok, I will try this tonight and let you know what happens :) thanks for your help
Posted By: xtremej
Date Posted: July 28, 2009 at 11:25 AM
Kenwood recently released updates for this model you may want to download.
