good setup?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115311
Printed Date: May 15, 2026 at 3:07 PM
Topic: good setup?
Posted By: imupabove
Subject: good setup?
Date Posted: July 27, 2009 at 1:59 AM
here is what i have:
IDA-X200
MRP-M500
TYPE-R 12
RF PUNCH 240X4
6022I'S
SPS-69C3'S
RF CAP 1 FARAD (MODEL#: RFC1D/DIGITAL)
i have the 4 channel amp hooked up to all 4 speaker as of now. the last thing to do now is to hook up the sub and mono amp. will it work if i get the power wire from the Punch and the power wire from the MRP-M500, and twist both power wires and put it inside the positive terminal of the cap? and put the power wire (4 gauge) coming from the battery to the other positive terminal of the cap (both wires 8 gauge). and ground everything separately (cap, Punch amp and mrp).
Posted By: spmpdr
Date Posted: July 27, 2009 at 11:45 AM
Yes it will work that way,My setup is wired using my cap as the distribution point for my amps as well.
-A vision without a plan is just a hallucination-
Date Posted: July 27, 2009 at 12:12 PM
when i do this installation, is it necessary to remove the negative terminal of the car battery? and when i charge the cap (i have the charge card that came with it) does the key need to be in the ignition?
Posted By: soundnsecurity
Date Posted: July 27, 2009 at 12:56 PM
no you shouldn't need the key to be on. also not necessary to take off the negative battery terminal just dont put the fuse in until you have everything ready to be powered up.
Posted By: spmpdr
Date Posted: July 27, 2009 at 3:06 PM
I have always removed the - terminal on all the installs i have done .Just personal preference though,it was the way i was taught
Date Posted: July 27, 2009 at 3:26 PM
well if i remove the negative terminal from car battery, the cap wont be able to charge the cap right?
Posted By: vibrationcustum
Date Posted: July 27, 2009 at 3:41 PM
after the first charge on a cap you can take of the - terminal on the battery and still have the charge. Cap goes into a standby mode. Unless you put + to - on the cap to dis charge it then you should be good. I done that to my cap and it is fine. Every install I do unhook the - battery terminal. I thank it is a safety thing for me. Just never know when something touch when you dont want it to.
Can't be loud then don't have it.
(power acoustik system)
Head unit- TID-896 7" TOUCHSCREEN
ovn1-5500d 09 and another one coming soon
4-12" mofos 12ft3 box to 40hz (wall)
2 batterys, 1 power
