splicing alpine ai net cable
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115325
Printed Date: May 15, 2026 at 2:28 PM
Topic: splicing alpine ai net cable
Posted By: tuscani
Subject: splicing alpine ai net cable
Date Posted: July 27, 2009 at 6:52 PM
Has anyone successfully spliced an AI-NET Cable from Alpine?
I have been trying to get ahold of the KWA-350 extension cable somewhere online, but everyone is out of stock as the item is discontinued from Alpine.
What does the AI-Net cable look like inside? Will it be a nightmare to splice?
Thanks in advance.
Posted By: i am an idiot
Date Posted: July 27, 2009 at 7:16 PM
I have never extended one, but I have repaired several that had been cut in half.  There is a 2 conductor shielded cable for audio, along with about 5 or 6 individual wires, all inside of an outer shield.   Radio shack sells (at least sold at one time) some 2 conductor shielded microphone cable that should work for the shielded audio cable.  To keep the outer shielding, you may want to extend all of the wires, fold the 2 ends of the shield back and wrap the entire length of the extension with some foil tape.  I use heavy duty aluminum foil but that is not for an extension.
Posted By: Ween
Date Posted: July 27, 2009 at 8:30 PM
hi,
i may have the cable you need...will check at work tomorrow.
m
Posted By: hinge817
Date Posted: July 28, 2009 at 11:20 AM
i have an old alpinecha-5604 that i havent used in forever account the cable end was pulled off when i took it out of a vehicle years ago. a friend tried to splice it back together but it kept saying error and wouldnt work. i did manage to get a new cable with good ends but i sold the headunit. i was just checking and seen this post. is my cd player salvagable?
Posted By: Ween
Date Posted: July 28, 2009 at 3:17 PM
checked at work...have the cable..new in packaging.
m
Date Posted: July 28, 2009 at 6:27 PM
Did you break the cable that comes off of the changer?
01T55619W08AI-NET CONN (HARDWIRED ET801)1 TO 2 DAYS< color=#ff0000>* $16.89
Or did you break the 5 meter long cable that connects the deck to the changer?
 01T55561W37AI-NET CABLE, 5MIN STOCK $24.76
1-800-421-5080   Pacific Coast Parts   pacparts.com
Posted By: hinge817
Date Posted: July 29, 2009 at 3:14 AM
i have a new 5 meter cable, but the old one had the end pulled off so my buddy  cut the connector off the cd player and tried to splice the long cable into the cd player, didnt work to well. so i did find a new cable and he put the connetcor back onthe cd player.
