cant find ground wire for 09 subaru wrx
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115505
Printed Date: March 29, 2026 at 6:38 AM
Topic: cant find ground wire for 09 subaru wrx
Posted By: hhuffman
Subject: cant find ground wire for 09 subaru wrx
Date Posted: August 06, 2009 at 6:27 PM
This is my first install and I can't find the ground wire. I have three harnesses. One is the main one without a black wire, the second is a smaller white harness with only 5 or so wires which includes a thicker cable wrapped in black electrical tape. The third is a single black and blue cable with grey spots on it and it's end says AMP. What do you think? Thanks, Heath
Posted By: t&t tech
Date Posted: August 06, 2009 at 7:04 PM
i can't give you any colours but i can give you a tip, just ground the wire on a piece of bare metal behind the console, Or if the deck is being mounted to a metal surface that is attached to the chassis, just fasten the ground together with one of the mounting screws!
Posted By: hhuffman
Date Posted: August 06, 2009 at 7:38 PM
Thanks for the head up. There is an odd round heavy duty bar that runs behind the headunit which may attach to the frame. Would it be OK to just solder it on there?
Posted By: i am an idiot
Date Posted: August 06, 2009 at 8:04 PM
Chances of getting that bar hot enough to solder to, without damaging your car, is going to be slim to none. Use a self tapping screw and a ring terminal. Run a second screw over the top of that to keep that screw from backing out.
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: hhuffman
Date Posted: August 06, 2009 at 8:17 PM
What is a ring terminal and I don't understand "another scre over that"
Date Posted: August 06, 2009 at 8:54 PM
Run a self tapping screw through the ring terminal and into the bar. Then run a second screw through the bar, placing the screw directly on side of the first screw. Have it close enough so the head of the second screw keeps the first screw from backing out of the hole. ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: hhuffman
Date Posted: August 06, 2009 at 9:49 PM
Perfect. Thanks for the explanation. I am praying to have this finished up tomorrow. I feel like such a redneck with no head unit and wires strewn around the dashboard. Thanks, Heath
Posted By: hhuffman
Date Posted: August 07, 2009 at 5:54 PM
Turns out that single black wire is a ground, not sure if that's what it was intended for, but I was told by a technician that it would would work fine. For a lower ground for the satelite radio I inserted the cable under the bolt that affixes the seat bas to the floor. Thanks for the help!
Posted By: yimke
Date Posted: August 07, 2009 at 6:20 PM
Or test for continuity to ground with whatever wire is in question.
Posted By: ajstetler
Date Posted: August 08, 2009 at 8:48 PM
Testing continuity is not a good practice. For one, if you happen to test an illumination or dimmer wire, you will wonder why the radio will only turn on when you turn on your lights. If you happen to test for continuity on a wire you think is ground, test that wire for illumination, dimmer, whatever. KNOW what the wire is! Test the constant with the suspect wire as "ground" to assure you have ground. Or like stated above, just run one! I have seen a few times where people come into the shop and ask me why their radio only works when they turn on their lights:) ------------- Big Al
