sub opinions?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115529
Printed Date: March 30, 2026 at 1:36 AM
Topic: sub opinions?
Posted By: metaljoey
Subject: sub opinions?
Date Posted: August 08, 2009 at 2:42 PM
hay, im stoked to "be a part" of the 12 volt!! now down to the dirty!  i would like some input on some subs i am looking at. i would like a good mix of sq and spl.  my ride is an '04 sebring. the system i have now is
h/u alpine cda-9855
memphis 16eq p7 parametric eq in the glove box
1/0 all the way back
x-static battcap (300 ?)
sub amp hifonics bxi 2610d
amp 4 mids and his hifonics zxi 8408
subs audiobahn aw1506t 15''s
the subs are in a lexan sealed box with 2.2cuft for each sub
front stage mb quart rsi 216
mb quart 6x9s out back
yellow top with 120amp stock alt. have not done the big 3 yet but i will.
i know this is NOT a "good" set up. its not like i payed a lot for it er nothing like that.i know the amps are over rated. i would like to think that bxi 2600d is putting out 1800-2000 maybe?i know that not a lot of ppl on here like hifonics and thats cool. i did not know mb quart was no longer the mb quart i remember.
but this is just to get me by for now. i had an all audiobahn system and i so wasted my coin!! its all teash!! so once i get some good subs i will upgrade the amps and replace the mb quarts with bostons.
for subs im looking @2 fi bls loaded or the q's, mtx 9500, memphis mojos, fosgate t2s or some re audios all 15". are these all spl sub im looking @?
i should be able to give them about 3-4cuft for each sub. ported and tunrd to 33hz er so. is there some other subs i need to check out?! let me know. any thing i get will be better than them audiobahns. thay do hit o.k. for the $134. i payed for em tho.
 thank you for your time!!
Before you see the light, you must die!!
Posted By: DYohn
Date Posted: August 09, 2009 at 9:36 AM
Fi or RE Audio would be my choice over MTX, Memphis or RF.
Date Posted: August 09, 2009 at 3:44 PM
would you have a suggestion on which re i might want to look at? i have been looking at the fi audios real hard. and i like the fact they are made to order, and built in thr usa!! i have not heard any thing bad about fi or re. all the time i have spent on here looking at the forums, i have come to respct you and the info you provide! thank you DYohn!!
