hifonics
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115550
Printed Date: March 29, 2026 at 2:36 PM
Topic: hifonics
Posted By: marosmaster
Subject: hifonics
Date Posted: August 09, 2009 at 4:23 PM
i recently purchased two (2) Hifonics Brutus 1200w single channel amps and two (2) Hifinics Brutus 10 inch subs and im trying to save some money so i'd like to install them my self but im not 100% sure how to wire them to the lowest possible ohm. could any one help????
------------- Maro's Master - ECAC
Posted By: icearrow6
Date Posted: August 09, 2009 at 5:22 PM
need more info on the woofers.
DUAL or SINGLE voice coils? and also the ohms.
Date Posted: August 09, 2009 at 6:36 PM
they are dual voice coil, 4ohm 1000w max
Posted By: ianarian
Date Posted: August 09, 2009 at 7:29 PM
Sup Maros, You have no options with that equipment, parallel is the only way. In which case you could of saved money using one amp for both 10's. Your wattage peaks at 1 ohm- * -both 10's wired parallel. Using both amps with both 10's wired parallel at 2 ohm is only 3/4 of each amps potential, but, since they are 10's, thats prolly ok. If I were you, Id stick to the forum if you feel it necessary to install yourself....ask before you buy is always a good idea.
------------- This is what I do for FUN!
Posted By: i am an idiot
Date Posted: August 09, 2009 at 7:34 PM
Option 1 (parallel) = 2 ohm load Voice coils wired in parallel Recommended Amplifier: Stable at 2 or 1 ohm mono |  | Option 2 (series) = 8 ohm load Wire each speaker as above. Connect one speaker to each amp. |
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Date Posted: August 10, 2009 at 3:22 PM
thanks for the help guys... i didnt realize that it was really that easy!
Posted By: KarTuneMan
Date Posted: August 10, 2009 at 8:27 PM
The fun starts when your bumpin and the headlights are keepin time!
Posted By: ranger1936
Date Posted: August 14, 2009 at 4:16 PM
sounds like rap. yuck! ;)
