fm antenna location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115573
Printed Date: March 29, 2026 at 8:41 PM
Topic: fm antenna location
Posted By: jeffwhiteman
Subject: fm antenna location
Date Posted: August 10, 2009 at 11:13 AM
Does anyone know where I can find the antenna connection in a 05 Volvo
S40. I want to add a FM direct for a sirius radio. I checked all the usual locations unsuccessfully. If not, any Aux. suggestions?
Posted By: yimke
Date Posted: August 11, 2009 at 12:16 PM
Best Buy should have them/any audio shop. I personally have 5 on hand just in case. Otherwise order them online.
Date Posted: August 11, 2009 at 12:57 PM
sorry I guess I wasnt clear. I was looking for the actual physical location in the car. It has a funky flat head unit but the antenna connection is elsewhere. I tried looking around various kick panels and behind the glove box etc. for the coupler. No luck. Any idea?
Posted By: jimi77
Date Posted: August 11, 2009 at 1:17 PM
Try a volvo forum...
You talking to me???
P9 Combo
ID CD1-Pros
Focal Utopia Midbass
10" Brahma
Clarion APX amps
Date Posted: August 11, 2009 at 1:47 PM
Thanks for the tip jimi77. I took your advice and found a volvo forum. I havent verified this yet but it looks like good info. The following was copied from the forum.
The Volvo AFM (AM/FM Module) is located behind the back seat. In order to access it, fold the rear seat down. This gives you access to remove the rear cover.
With that removed, you can see the AFM. There is a cable coming out of the right side, closest to the rear of the car. This has two MCX style connectors that connect to the antenna.
What I did, was buy two adapters. Circuit City sells them as something like "VW/BMW/European Car Antenna Adapter." You need two different cables - one male motorola to female MCX, and one female motorola to male MCX. You will also need an FM Modulator.
Those two cables come with plastic snap on housings that don't fit with the AFM. You will have to cut those housings off, being careful not to damage the cable or connector.
Posted By: jimi77
Date Posted: August 11, 2009 at 4:34 PM
Good Luck.
P9 Combo
ID CD1-Pros
10" Brahma
Clarion APX amps
Posted By: yimke
Date Posted: August 13, 2009 at 9:20 AM
...... You realize you could have saved yourself a headache an just buy the volvo antenna adapters for yor FM direct and just went behind the stereo?
Date Posted: August 13, 2009 at 1:07 PM
That was the problem. There is no antenna connection behind the "stereo". The RF is fed into the AFM (AM/FM Module) located behind the rear seat. apparently this is where the demodulation is done. The "stereo" up front is simply a controller. No RF!
Posted By: yimke
Date Posted: August 14, 2009 at 11:40 PM
hmmm never seen that in a volvo before. A couple Mercs, and BMW's but no volvo.
Posted By: paidnfull
Date Posted: August 15, 2009 at 9:43 AM
Anything after about 04 is set up that way.  I worked on an 06 xc90 yesterday and the only lines goin into the antenna were fiberoptic and 12v.  We just used the xm sureconnect and put it right on top of the antenna.  Works as good as any wireless transmitter can work.
