port
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115586
Printed Date: March 30, 2026 at 1:36 AM
Topic: port
Posted By: dodoandduck
Subject: port
Date Posted: August 10, 2009 at 7:34 PM
I was wondering if there are any positives/negatives to where your port exits the box. I.E. front firing or rear firing. My thought was a rear firing port into the trunk so I won't have port noise in the cab.
Posted By: whiterob
Date Posted: August 12, 2009 at 1:40 AM
I would typically put the port on the same plane as the sub(s). If that was not a possibility then putting it somewhere else shouldn't really matter. Just don't put it where the exit will be obsrtucted by the walls of the vehicle.
Why do you plan on having port noise? If you design the port properly you won't need to worry about having port noise.
