stereo wiring for swc hu
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115650
Printed Date: March 31, 2026 at 12:11 PM
Topic: stereo wiring for swc hu
Posted By: darktari
Subject: stereo wiring for swc hu
Date Posted: August 14, 2009 at 2:26 PM
Can anyone help ?
Trying to connect a PAC SWI-X  unit to a recently installed Pioneer AVH-P4000DVD.  There is one white wire from the PAC harness that needs to be connected to function.  Where this wire connects I do not know. In the 2006 xB HU w/SWC there are 4 sets of connectors which have no id, one of which is the SWC.  ( Power / Speakers / SWC / iPod & Aux)
Need the wiring diagram for a 2006 Scion xB with SWC (steering wheel controls) that includes the additional scheme for the SWC & iPod/aux inputs...
Thanx !
DarkTari
Turn It Uuup !!!
Posted By: yimke
Date Posted: August 14, 2009 at 8:02 PM
Do everyone a favor and return the SWI-X. It is junk b/c it is infra-red and is highly effected by light. Buy the PESWIPS or SWI-PS module.
Heres the instructions https://76.12.243.71/swixprogramming/showstepbystep.asp?InterfaceChecked=3&RadioGroupPioneer=0&mmSearch=Scion&Submit2=Search+Vehicles&ID=386
Looks like you use pin 6,7, and 8 with 150 ohm resistor. If you're not comfortable doing this consult a professional for install.
Posted By: darktari
Date Posted: August 14, 2009 at 10:05 PM
Thanx Yimke !!!!
I found & have these instructions archived.  They specify the SWI-PS not the SWI-X.  Does it matter ????  Is the only difference the SWI-X is infrared and the SWI-PS is not ?  And the PESWIPS, will it work with my car ??
Thanx
DarkTari
Turn It Uuup !!!
Posted By: yimke
Date Posted: August 14, 2009 at 11:56 PM
PESWIPS and the SWI-PS are the same thing only different manufacturers (technically).
But read my first part of the post. Return the SWI-X and buy either the SWI-PS or the PESWIPS. You will thank me down the road. And your unit has the capability to run these since it has a remote input on the back of the unit.
The SWI-X is a last resort for me because it is infrared and it can be disrupted by sunlight. In other words (A giant pain in the you know what) I only use this if the customer is in love with their unit and it doesn't have a direct input for steering wheel controls.
Once you get that, then we can help you if you are still having technical issues.
Posted By: darktari
Date Posted: August 16, 2009 at 6:56 AM
Thanx 4 all your help Yimke, will do !!!!!!
DarkTari
Turn It Uuup !!!
