hooking up a 4 channel amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115657
Printed Date: March 31, 2026 at 4:36 PM
Topic: hooking up a 4 channel amp
Posted By: palone18
Subject: hooking up a 4 channel amp
Date Posted: August 14, 2009 at 8:25 PM
Just simply how do you hook a 4 channel up to door speakers? i know you need power and ground. which rca cables do you plug in? and do you just unhook your speaker wires fron the harness and plug them in? help please
Posted By: i am an idiot
Date Posted: August 14, 2009 at 8:55 PM
Does your radio have both front and rear RCA jacks?
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: palone18
Date Posted: August 14, 2009 at 11:19 PM
i am pretty sure, its a kenwood. a newer one
Posted By: yimke
Do you have an aftermarket stereo or factory?
Usually i just run RCA's from the deck to the amp. And then run speedwire from the amp back to the deck and catch all my speakers there.
Date Posted: August 15, 2009 at 5:40 AM
If it has front and rear outputs, using 2 stereo patch cords, connect the front output of the radio to the front input jacks of the amplifier. Then connect the rear outputs of the radio to the rear inputs of the amplifier. Cut the speaker wires from the radio where it connects to the harness. Insulate the wires that come from the radio. Extend the wires on the harness long enough to reach the amplifier. Connect the appropriate speaker wire to the appropriate channel of the amplifier.
Posted By: palone18
Date Posted: August 15, 2009 at 10:31 PM
thank you, thats all i needed to know. thanks :)
