Want To Set Gains With DMM
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116062
Printed Date: April 18, 2026 at 8:29 AM
Topic: Want To Set Gains With DMM
Posted By: jdubicki
Subject: Want To Set Gains With DMM
Date Posted: September 02, 2009 at 4:23 PM
Hopefully you guys can help. This is what I have:
HU - Pioneer DEH-P2900MP
Amp- Alpine MRP-M500 500 Watts @ 2 ohms
Subs - MTX Thunder 4000 200RMS/400Max
DMM - Ideal 61-310 Looks like this:
posted_image
Did the formula 400 x 2 = 800, sq root = 28.29
Using 50 Hz test tone and looking to get 30 volts on meter. I can barly get 2. I have tried the different settings on the DMM, but really not sure which one to use. Pretty sure test tone is at 0 db. Please help.
2005 Honda Accord DX
Posted By: DYohn
Date Posted: September 02, 2009 at 4:34 PM
AC volts, 200-volt scale, meter leads connected to the COM and Temp-V-Ohms terminals, measurement taken on amplifier speaker output with the speaker disconnected.
Posted By: jdubicki
Date Posted: September 02, 2009 at 6:56 PM
The speaker has to be completely disconnected?? I have read that you need a load. Some say one terminal connected, others say both. I have done it with pos disconnected and cannot get a reading.
Posted By: DYohn
Date Posted: September 02, 2009 at 7:22 PM
The speaker should be disconnected.  If you cannot get a reading first make sure your meter works.  Test it at a household outlet that you know works.  Also, you are trying to set a level with a 50Hz tone?  Are you sure the crossover or the Xover in the amp is set to LP and at about 80-100Hz?
Posted By: i am an idiot
Date Posted: September 02, 2009 at 7:44 PM
You must connect both meter leads to get a reading.  Red lead on positive speaker terminal.  Black lead on the negative speaker terminal.
Posted By: DYohn
Date Posted: September 02, 2009 at 7:46 PM
Ah yes, I often forget to mention the most basic part of the instructions.  I guess I assume too much sometimes ... thanks!
