amp setting for component speakers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116462
Printed Date: May 01, 2026 at 8:16 AM
Topic: amp setting for component speakers
Posted By: stlyidklr
Subject: amp setting for component speakers
Date Posted: September 21, 2009 at 11:27 AM
Right now I have a cheap power acoustic amp running some MB Quartz component speakers.  That amp is getting ready to die...shocker!  For my next higher quality amp, do I set the filter at high or full for the components?  I have MB Quartz in both the front and the back of my truck.  My amp for the rear speakers has already died.  So, I'm either going to go with a 4-channel or 2 2-channel.  Any suggestions there?  Thanks!
Posted By: haemphyst
Date Posted: September 21, 2009 at 11:37 AM
I've never heard of MB Quartz speaker systems, so I can't really tell you what that manufacturer's recommendations are.
Generally speaking, set the amplifier's high-pass to 80Hz or higher, to start. If you find you can't get adequate output with that frequency without the woofers "banging against the stops", raise the frequency. Personally, I'd never go much higher than about 100Hz, but that's just me. Others here might suggest differently.
A single 4-channel amplifier will have a smaller footprint than two 2-channel amps, and be easier to install - 1 power, remote and ground wire - and neater looking, IMO, as well. There is no "right" or "wrong" way, however.
Date Posted: September 21, 2009 at 11:58 AM
Thanks for the quick reply and info.  I made a miss type for the speakers.  They are MB Quart, no "z".  And the models are DSD-216 6.5" in the front and DUA-210 4" in the back.  I have them installed in a 2001 Nissan Fronteir Crew Cab.
Posted By: ianarian
Date Posted: September 21, 2009 at 8:09 PM
Im with haemphy on the 100hz, sometimes even higher. I've noticed that higher quality amps get away with a lower Hz level. Perhaps due to clearer sound. Without subs, I would set my system to flat or the minimum HPF level.
This is what I do for FUN!
Date Posted: September 22, 2009 at 12:35 PM
I've squeezed in an Audiobahn 1051T subwoofer in the back run by a Kenwood KAC-7204 also.  I don't know if I have enough room to have a 4 channel under my seats.  I've already had to do some modifications to get the 2 2-channels to fit. Thank you both for the info!
