big3 on a 93 deville
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116593
Printed Date: May 01, 2026 at 11:30 PM
Topic: big3 on a 93 deville
Posted By: still_walkin
Subject: big3 on a 93 deville
Date Posted: September 28, 2009 at 6:07 PM
I have 93 deville 4.9L engine and I trying to do the big3 . The problem is I've done it before but this time the alt and battery is on the same side. So that means all that 0 guage on one side of the engine so what I came up with pos battery Y spliter 0 guage then fuse both ends with one fuse each. On the battery ground and alt ground can I use the same ground and y split it or use the batterys factory grounding spot and the alt make a new ground. Thanks
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
Date Posted: November 29, 2009 at 2:24 PM
Ok this is my only problem now since the alt and battery is on the same side can I use the battery chasis ground for the alt. or I have to make a new ground for the alt.
1993 sdv
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
