crx aftermarket alty/ stock plug issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116641
Printed Date: May 02, 2026 at 5:44 PM
Topic: crx aftermarket alty/ stock plug issues
Posted By: upzaw2000
Subject: crx aftermarket alty/ stock plug issues
Date Posted: October 01, 2009 at 10:02 AM
A few things UP FRONT
1. Yes i have tried to contact EA
2. My Grounds are very good :)
Heres the issues... I just installed an excessive Amperage 200 amp s10 alty with an external voltage regulator into my 89 crx dx 1.5 liter... There was no place to plug in the stock alty plug to the PCM. So its just dangling there... The lights in the car and the idle flickers (dims and brightens) as the engine revs. The higher the load placed on the car... the worse the effect.
One of my teamates came over last night and said that the stock Alty plug might need to be miniputed in order for the PCM to stock affecting the idle.
I checked the alty plug and found there are 4 different pins... 2 veritcal pins parralell on top and 2 horizontal pins below the vertical pins...
The top Vertical pins are ingition hots showing the cars voltage...
The bottom left pin is a ground
The bottom right pin appears to be a field line showing around 4.5-4.6 voltage (guessing thats the voltage regulator pin for hte stock one)
We did some testing throwing loads on the car and checking the stock alty "FIELD" pin and it fluctuates as we place a load on there as if the pcm is trying to control it and having issues...
Any assistance would be appreicated! IM LEAVING FOR WORLD FINALS TOMORROW EEEEK!
Team Southern Bass
Team Sundown Audio
Team Cascade Designs
89 Crx Dx - Automatic :)
Date Posted: October 01, 2009 at 11:34 AM
i probably have this in the wrong section... but... ya
Team Southern Bass
Team Sundown Audio
Posted By: jeffchilcott
Date Posted: October 01, 2009 at 7:08 PM
Im having the same issue with my irragi alt on my Civic coupe.....I redid the grounds and it has gone away about 90% but still there after the car warms up.
I just plan to make sure the car is good and cold at finals    LOL
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: October 01, 2009 at 9:28 PM
Ol and it just gets worse as the load gets biiggger...
Only thing I'm worked about is when it does this I lose alot of control over the voltage and I don't wanna be dq'd
Team Southern Bass
Team Sundown Audio
Date Posted: October 01, 2009 at 11:54 PM
when you get down to tulsa, come find me or josh brown.    Josh would probably be best to get it figured out..
I have redone my power/field/and ground wires on my alt to get it working right
2007 World Record
Date Posted: October 02, 2009 at 10:42 AM
Kool I'll do that. Thanks
Team Southern Bass
Team Sundown Audio
