Running a DVC sub with a 2 / 4 ohm relay
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11687
Printed Date: May 16, 2026 at 11:59 AM
Topic: Running a DVC sub with a 2 / 4 ohm relay
Posted By: vseven
Subject: Running a DVC sub with a 2 / 4 ohm relay
Date Posted: March 31, 2003 at 5:22 PM
I was looking to impliment a relay switch like that in the relay section ( Switching from Series to Parallel and Back) but going from 2 ohm to 4 ohm. Is this possible for a DVC sub? I was looking at a Infinity Kappa Perfect 10.1D. It has two voice coils and I was thinking you can run it with only one voice coil, then through a relay parallel the other voice coil with it if you press a switch, making it a 2 ohm load, which should double the power output. Can this be done, or is there a reson it shoulden't be?
Allan.
Posted By: bberman1
Date Posted: March 31, 2003 at 6:01 PM
You cannot only use only 1 voice coil on a DVC you will get sound but it will damage the speaker.
Posted By: dragonrage
Date Posted: April 01, 2003 at 9:28 AM
bberman, please explain why. It makes no sense to me that that would be the case. There would be no multiple magnetic fields to screw anything up. It just seems to me that you'd only be able to run half the power.
------------- 2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
Posted By: themagicone
Date Posted: April 01, 2003 at 9:34 AM
Try it and see what happens.... You will start to smell something burning and it will be your sub. I'm not for sure how they work and why they won't work with only one coil but they burn if you only use one.
Date Posted: April 01, 2003 at 9:36 AM
Well, I'm not going to try it, but that doesn't make me believe anything because it doesn't say why at all.
HU: ?
Speakers: ?
Amps: ?
Posted By: vseven
Date Posted: April 02, 2003 at 7:01 PM
Yeah, this dosn't make any sense. One would think if your powering a single coil your just not getting as loud. Its not as if one coil does have the speaker, it should go all around. Does anyone have a good reason this woun't work? It would be nice to be able to run 4ohm and switch to 2 (doubling the power) with a button instead of from 8 to 2, having a huge difference.
Allan.
